Differences in lifters
Old Sep 12, 2011 | 07:27 AM
FLSTF's Avatar
FLSTF
I'm running the V-Thunder 875-1 lifters in my build with Wood tw68g's and they are very quiet. I asked Wolfgang if he thought they would be ok and he said yes. Spoke with someone in the tech dept. at Comp Cams and they told me the 875-1 wasn't the short travel lifter, that it has .160 travel. So far they are working fine.
Old Sep 12, 2011 | 09:43 AM
djl's Avatar
djl
.160" is short travel; typical is .200" and the 875-1 is probably the better choice over the 850-1 for those cams. The 850-1 is, IMHO, a better choice for a big bore build with "bolt in" cams. Both the 850 and 875 are good hardware but you should be sure and talk to the parts guy at CompCams and make sure you get Delphi lifters, not brand X.
Old Sep 12, 2011 | 05:40 PM
Stiggy's Avatar
Stiggy
Good time for this question perhaps:
If you start at say .010" and adjust from there, ( my Black Ops run about .014,) what in the lifter gives an advantage to one adjustment vs the other?
In other words, if it is an 'adjustable' lifter, wouldn't the proper tension be achieved simply because the lifter is going to expand until it has no place to go, whether you start at .010 or end up with .014 as I did?
And it would follow, what advantage to a short travel lifter, higher rev capability perhaps?
Old Sep 13, 2011 | 06:04 AM
FLSTF's Avatar
FLSTF
I agree .200 is typical, it's just the way he said it made it sound like they had even shorter travel lifters. Maybe he just didn't consider .160 short. I called because someone else told me they were only .100 deep and I wanted to make sure I didn't go too far into the lifter. I seem to be going through an endless learning curve. LOL
Old Sep 13, 2011 | 09:12 AM
djl's Avatar
djl
Nout sure I understand your question but will take a stab and answering what I think your question is.
You have neglected to include the bleed down as part of your logic; every lifter has a bleed down rate. If hydraulic lifters didn't bleed down, they would be solid lifters. The cylinders grow taller as they heat up and increase the valve train stack up dimension. As the cylinder grows, the hydraulic lifter pumps up to maintain zero lash. Some lifters bleed down faster than others and the internals of the lifter, the viscosity of the oil, the oil termperature, machining tolerances and engine rpms affect the bleed down rate. When a lifter goes bad and bleeds down faster than it should, the bleed down introduces lash into the valve train and results in the noise some find so annoying.
When a lifter bleeds down it alters the valve timing as the lash has changed. On a hot start, the change in valve timing raises the CCP and this makes hot starts more susceptible to kickback. A limited travel lifter has less less room to bleed down and thus the valve timing is more consistant hot or cold. The other benefit is should valve float occur the limited travel will/should not allow the valve to come into contact with the piston as the lifter pumps up in it's attempt to maintain zero lash.
Old Sep 13, 2011 | 05:58 PM
Stiggy's Avatar
Stiggy
djl,
Thanks for spending some time helping me understand, ( and maybe some other readers too.) I appreciate it!
Old Sep 14, 2011 | 10:54 PM
Mike's Avatar
Mike
Many swear by Black Ops. If you are that worried about lifters, pony up for a set of the Woods directional; they are the best.
How are they better than the HQ lifters? Not wanting to start an argument, I'm just wonding what you base the statement on.
martin10
Engine Mechanical Topics
Dec 10, 2015 11:46 AM
adm
29
Sep 30, 2015 06:00 PM
silverado636
Oct 6, 2011 01:27 PM
91lowlyf
Apr 8, 2011 05:15 PM
thewholehog
May 29, 2010 01:41 AM
