Adjusting Super E.
I've never played with one of these Harley carbs but I've worked on carbs before.
Bike is a custom softail 96" S&S. Super E carb shorty. Big sucker intake. All stock internals. It had LAF pipes on it and of course they where mega loud. Ran fine, I guess. Too distracting for me. I bought a set of Rush mid length pipes. Baffles and 1 3/4" pipes. Put them on and bike runs great. Much better low end. Pulls better sounds better etc etc. Not real happy with the sound when backing off the throttle. It's a whispy windy noise.
Cold idle takes about 30 seconds of assisting the throttle to idle without stalling. Warmed up, idles forever.
So I pulled the baffles....Oh yeah!! That's it. Louder but sounds much better. I'm ok with it. Idles good warmed up and pulls strong. God this EVO vibrates.
The problem is, at steady state low rpm/barely any throttle, cruising it seems lean to me. It surges a bit. Not too bad but would be nice to try and correct it.
I know where all the adjustments are on the carb....little more accl pump or maybe a bit more fuel mixture??
I dunno, so I ask.
Thx for any help....
Idle mixture is adjusted by slowly turning idle mixture screw in (clockwise) until the bike runs rough. Now back it out slowly just enough to make it run smoothly. Idle speed should be around 1,000 RPM, which gets set via the idle speed screw (as opposed to the idle mixture screw).
I dunno, so I ask.
Drag pipes on an Evo........
Install an 1 1/2" long 1/4" bolt in the pipe using the hole that held the baffle, and stack 4, 5/16" nuts on it, and then nut it with a 1/4" nut.
It'll have all the racket you have now, but it'll control the reversion that occurs with open pipes.
Now, moving to the carb.......
Base line jetting for set-ups like that, from what we've found is as follows;
.0295 pilot, 1 1/2 turns out air/idle screw, bottom the accelerator pump screw and back it out 3 turns, and a .070 main jet.
This should get you into a civilized fuel curve, and then you can makes moves as needed from there.
Scott
if it's surging/jerking then which way should I go in or out on the screw?
The bike didn't do this with the LAFs or the baffles in. I might have created this.
I will do the bolt and washers. I read that gives it a little back pressure to help along.
Thx for the help by the way.
Scott
