Running rich
Old Oct 27, 2011 | 12:44 PM
jaredb's Avatar
jaredb
Default Running rich
Hello I have a problem and having a brain fart. I have a 1990 and I got the carb tuned up to some new pipes last year. I basically run it right off back fire.. Kind of on the lean side. But the problem is, my pipes are turning gold and when I check my plugs, they have soot on them (black), to me means signs of richness. It'll run hot hot then I'll give it more gas. Sounds to me I need something done with my jets. My question is bigger or smaller. Thanks for reading..
Old Oct 27, 2011 | 12:53 PM
Shredding rubber's Avatar
Shredding rubber
What. Your running rich and still a backfire? That would be an exhaust gasket leak.
Old Oct 27, 2011 | 01:11 PM
jaredb's Avatar
jaredb
No. I guess I didn't explain it right. I leaned it till it backfired, then riched till it stopped backfiring. Then it ran very hot and made a little more rich to get the temp down. It doesn't backfire now, just runs rich. And if I lean it anymore it'll run hot and backfire.
Old Oct 27, 2011 | 02:05 PM
Panshovevo's Avatar
Panshovevo
Are the plugs wet or dry? If wet, have you considered the possibility
that it ran hot enough to cook the valve seals?
Old Oct 27, 2011 | 02:12 PM
jaredb's Avatar
jaredb
Not wet. And when I say hot it oil temp was never above 230 and it runs good. Just gold pipes and soot on plugs.
Old Oct 27, 2011 | 02:14 PM
Clayvis's Avatar
Clayvis
Is the timing set right? How many turns on the mixture screw does it take to go from lean to rich? Something aint right....
Old Oct 27, 2011 | 02:17 PM
jaredb's Avatar
jaredb
Timing is right. I think its like a turn and a half out now. But this summer is turn it like 8ths out till the temp went down.
Old Oct 27, 2011 | 02:20 PM
jaredb's Avatar
jaredb
I meant I'd turn it not is.
Old Oct 27, 2011 | 08:27 PM
pnw_hd_rider's Avatar
pnw_hd_rider
Back firing through the exhaust indicates rich, not lean (coughing through the carb indicates lean). Black 'soot' on the plugs also indicates rich condition.
Pipes turning gold and/or blue close to the cylinder heads (where they get the hottest) is normal. Most people cover that part of the pipes with heat shields.
Old Oct 29, 2011 | 08:33 AM
jaredb's Avatar
jaredb
I guess you guys aren't getting my question... nevermind.
