Which cams?
I don't want to worry about these danged cam chain tensioners anymore - well, that's a good excuse anyway. So - gear drive cams!
At this point, I've done Stage 1 (K&N RK-3909 a/c, PCB-III USB, V&H Pro Pipe), and other than the cams, I'm not planning any more hop-up work AT THIS TIME. I may go the big-bore/porting route sometime in the future (would NOT expect to go high-compression, maybe a small bump at most), but I'm willing to accept that that may - probably will - mean another cam change at that time. (Obviously, not having to do so is even better, but probably not realistic...?)
The bike has a great power-band - not as much oomph up top as I'd like, but is there ever? I don't want to lose torque in the low and middle ranges. Ideally, a little more there, plus some more on top - yeah, I want it all!
I ride solo and two-up, back roads and highways - all types of riding.
Three cams I've heard good things about that SEEM to fit the bill are Andrews 26G and 31G, and S&S's 510G. Open to all suggestions, however!
Anybody got any advice?
I appreciate it, folks. - BrianK
The 26 is a great all around cam, espically for motors with little other mods and 9.3:1 or less compression ratio.
The 510's will make a bit more power power at higher RPM than the 26's, but like 9.7:1 CR.
THe 31's are a lot like 37's, but like 10:1 CR.
Given your stated goals and ride style, the 26's are probably the best bet, at least of those three.
Another option, very similar to the 26, but with slightly more potential (espically in a light bike, like a Deuce) would be the HeadQuarters HQ-0034.
I'm sure others will have plenty of additional input nad opinions....
My PCIII should be here tomorrow (friday) and i'm hoping for some more gains. Once i get the GMR 98" kit and the heads done (Big Boyz) i think it's going to **** and Git!
