cam swap, now no fire on rear cyl.
Old Feb 18, 2012 | 01:07 PM
jwright302's Avatar
jwright302
Default cam swap, now no fire on rear cyl.
07 dyna with DD 2-1 fat cat and Thundermax
WAS running 107 ci kit with wood 555 cams and lifters, stock heads and adj pushrods. Put 12K miles on last year on this set up.
NOW this winter i tore it all down again to get jugs, heads, and pushrod tubes powder coated And got the Level B fuel moto job to the heads with comp releases. Decided to sell my 555s and try the 777s. I installed the cams, checked and double checked the timing marks, checked and double checked the pushrods. Finally got it all back together this morning and it will only run on the front cylinder.
Spark is good, checked it with a spark checker tool (also tried another plug)
Plug gets wet and smells like gas.
Checked and changed map, still no change.
I don't have a compression gauge, I do hear the air rushing out of the comp releases.
I want to check anything and everything i can before i have to tear the god awful headers off this thing. I'm pretty positive all the timing marks are going to be exactly right, but what else could it be ?? thanks in advance
Old Feb 18, 2012 | 03:06 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Make sure the plug wires are not switched.
Scott
Old Feb 18, 2012 | 03:11 PM
jwright302's Avatar
jwright302
Thanks Scott. Actually checked that first, bottom spot on the coil is the front cylinder.
Old Feb 18, 2012 | 03:14 PM
soft 02's Avatar
soft 02
?Comp release stuck open?
Old Feb 18, 2012 | 03:25 PM
soft 02's Avatar
soft 02
What about the head sensor causing the EIMTS to kick in wich cuts out one cyl.? Just a thought.
Old Feb 18, 2012 | 03:26 PM
ConnMan's Avatar
ConnMan
Bad plug wire?
Old Feb 18, 2012 | 03:27 PM
jwright302's Avatar
jwright302
Just checked those both out. Seem to be working properly.
Old Feb 18, 2012 | 03:30 PM
ConnMan's Avatar
ConnMan
Bad plug? Swap 'em out and see if the problem "moves"?
[I'm guessing here, but you seem like you know what you're doing, and it's usually something "stupid" like this...]
Old Feb 18, 2012 | 03:33 PM
jwright302's Avatar
jwright302
Is that the "mode" it goes into when the engine gets too hot ? If so I don't think the Thundermax has that mode. Also I've linked up to it With my laptop and it doesn't show any codes.
As for plug wires, I tried a spare one and a spare plug, I even have a spare coil that I tried. With my spark checker tool, it's showing a strong spark. So I have spark and seem to have fuel to the cylinder ( wet plug smelling of gasoline).
Old Feb 18, 2012 | 03:34 PM
soft 02's Avatar
soft 02
If it is the head sensor then it wont throw a code it will just think the engine is hot. Check the connection.
