engine knock
Old Feb 26, 2012 | 09:32 AM
RHillbilly's Avatar
RHillbilly
Default engine knock
Installed 107 kit with woods777 cams had about 100 miles on it went to start motor cold knocked for split second all was good so i readjusted pushrods still knocks on start up .went to go on ride started up knocked thought maybe lifter needs to pump up after about ten miles goes away runs fine,next day start up knocking wont go away sounds like front cyl tear rocker box checked compression 190 both cyl took cams out heads off cant find anything wrong going to change valve springs but still baffled
Old Feb 26, 2012 | 11:32 AM
djl's Avatar
djl
What lifters?
Old Feb 26, 2012 | 12:16 PM
RHillbilly's Avatar
RHillbilly
Woods its a fuel moto kit they are sending valve springs to try i cant see anything wrong maybe whem we get thd springs we will see something when we change them
Old Feb 26, 2012 | 02:58 PM
djl's Avatar
djl
Doubt it's the lifters. Could it be a rocker arm making contact with the rocker cover? I have had that happen before with .590" lift cams. If springs are not beehive, you might need to clearance the rocker boxes in the spring corners. Open the link for an illustration. This might not be an issue but you should be able to tell if it is by looking at the underside of the rocker box for evidence of contact.
http://www.tmanperformance.com/pdf/rocker.pdf
Old Feb 26, 2012 | 03:56 PM
RHillbilly's Avatar
RHillbilly
I dont see anything hitting rocker boxes the guy at fuel moto thinks it is a weak valve spring says the valve could be bouncing
Old Feb 27, 2012 | 06:01 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Before I'd do anything, I'd toss the OE lifters back in, and adjust .140-.150" pre-load, and witness any differences.
Simple, cost-nothing approach.
Scott
Old Feb 27, 2012 | 06:25 AM
RHillbilly's Avatar
RHillbilly
Yea am going to change lifers but have to get gaskets and put heads and cams back in pulled everything to make sure
texashillcountry
EVO
Jan 28, 2014 09:00 PM
Stiggy
11
Apr 27, 2013 08:50 AM
2009blackpearle
Aug 9, 2012 01:04 AM
bobbyjoes
May 28, 2012 10:57 AM
al baehr
Jul 6, 2011 10:18 AM
