Engine mount replacement
Old Mar 1, 2012 | 05:33 PM
SgtDuckyBoy's Avatar
SgtDuckyBoy
Default Engine mount replacement
Tried to search but couldnt find it in manual or on this site. I need to know what the steps are to replace the front lower engine mount. I have the engine supported on a jack, removed main center bolt and two side bolts and yet the engine is still holding pressing down on it. do I need to lift engine higher? will it move as i keep jacking or do I need to loosen/remove other bolts/mounts on the rear of the engine/crank/tranny components.
thanks!
Old Mar 1, 2012 | 06:52 PM
SgtDuckyBoy
well, raised the jack and the engine raised up! got the old one out,, now getting the new one in is the problem.... grrrrr
Old Mar 1, 2012 | 07:49 PM
SgtDuckyBoy
ok, figured it out... loosened the two bolts that hold the engine to the top of the engine mount, this gave the plate enough room to lift up and let the mount go sliding underneath it! all back together now and tight! engine vibration gone!
Old Mar 1, 2012 | 08:43 PM
DaveCarlson's Avatar
DaveCarlson
Glad I could be of help!!
Old Mar 1, 2012 | 09:05 PM
djl's Avatar
djl
Ain't it great when a plan comes together!
Old Mar 2, 2012 | 12:19 AM
SURFOR Chop's Avatar
SURFOR Chop
I was about to ask what bike when I noticed the small print under your name ... I am assuming your questions and subsequent resolutions referred to your 2001 Road King ...??
I haven't looked closely at my service manual to see if it discusses the procedure for replacing the motor mounts ... guess this info might be helpful for me if, as and/or when it comes time for me ...
wle72
Oct 31, 2012 08:19 PM
russell6hp
Mar 24, 2010 05:55 AM
Gary7
Apr 16, 2009 05:09 PM
Yellotang
Sep 18, 2007 09:29 PM
Pipedope
Jul 11, 2007 12:27 AM
