Engine / Primary rattle
Old Jan 1, 2007 | 12:02 AM
steventh's Avatar
steventh
4th Gear
Default Engine / Primary rattle
I recently had the primary sprocket on my '89 Electraglide replaced (the belt had previouslybeen replaced with a chain).
Since then, under light load the engine / primary "rattles". This doesn't occur under heavey loadandthe rattling will stop if the engine is under load. It will also occur if the engine is revved in nuetral. I haven't been able to identify if the noise comes from the engine or the primary.
Any suggestions on possible causes would be appreciated.
Thanks in advance
Steven
Old Jan 1, 2007 | 09:37 PM
bobcowan's Avatar
bobcowan
Default RE: Engine / Primary rattle
Loose primary chain?
Old Jan 2, 2007 | 04:27 AM
Biggzed's Avatar
Biggzed
My bet would be a loose comp nut.
Old Jan 13, 2007 | 10:26 AM
steventh's Avatar
steventh
4th Gear
Hi Folks,
Thanks for the suggestions. I have checked the primary tension which is OK.
I will also check the compensator nut.
regards
Steven
Mcdoua1
Aug 6, 2020 05:55 AM
albatross
Milwaukee Eight (M8)
21
Jan 31, 2019 10:54 AM
lee.moore
Feb 5, 2011 08:44 PM
jadev
Jun 18, 2008 09:37 PM
larry5h
Oil Archive (no new posts)
Mar 26, 2007 03:13 PM
