Losing oil in shovelhead
Old May 2, 2012 | 11:53 AM
matt82sturgis's Avatar
matt82sturgis
Stage II
Red face Losing oil in shovelhead
I was told after bringing my shovel after losing power in back motor...
- we changed the plugs to a lower wtvr
- Your piston are not seating
- whoever did your engine work didnt put the valves in correctly.
- So I am losing oil and the plugs are failing
- I have put 1000 miles on since bottom was redone and 500 since top was redone by an AA hillbilly who was mad at me because he is a loser...
So woth all tha being said!
What do I need to do
I AM AT THE POINT WHERE i WANT TO START WRENCHING BECAUSE I AM GOING BACK TO DENVER ADN DO NOT WANT TO NOT KNOW ANYTHING
Old May 2, 2012 | 12:08 PM
matt82sturgis
Stage II
it is a 1982 shovelhead by the way)
Old May 2, 2012 | 12:54 PM
72fl's Avatar
72fl
Whats the question ?
Old May 2, 2012 | 01:21 PM
Big Trev's Avatar
Big Trev
interpretation please
Old May 2, 2012 | 04:56 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
No valve seals installed?
Rings butted/installed incorrectly?
Incorrect cross-hatch?
Cylinder head gasket surface buggered, causing incorrect seal at the cylinder drain?
Any/all of the above could be the reason.
Scott
Old May 2, 2012 | 05:11 PM
72fl's Avatar
72fl
woth tht all boing sid mez thank youlust a bunka munky
Old May 3, 2012 | 12:25 AM
j1mmy's Avatar
j1mmy
kind of confusing. might be time for a new top end,or at least a second opinion.. i had a shovel that liked to foul plugs, had a valve not seating.. took the heads to a napa machine shop. $40 and they were like new..
..it sounds like ether you didn't understand what the mechanic told you, or he didn't have a clue in the first place.. is the oil level actually going down(you need to keep adding oil)? HD's are pretty low tech. most likely,the rings are seated fine unless some one really screwed up building it: cyls bored way too big, no crosshatch, worn broken wrong or missing rings..
..if it is just fouling plugs, heads/valves would be the first thing to look at. could be as easy as pushrods adjusted wrong. if they are too tight,the valves are held open and that is your problem.
tinkering
Engine Mechanical Topics
23
Jan 5, 2022 05:17 PM
Micromark
Jun 10, 2019 11:57 AM
BassFace
Shovelhead
29
Aug 14, 2016 09:44 AM
f2titan
Jun 4, 2007 01:28 PM
sickchoppers
Oil Archive (no new posts)
Mar 31, 2006 12:02 PM
