Backfire
Old Jul 1, 2012 | 10:27 PM
Johncarneiro's Avatar
Johncarneiro
Stage II
Default Backfire
I have a 2012 softail slim with a big radius 2 into 2 and a power v commander with backfiring, is that normal?
Old Jul 1, 2012 | 10:29 PM
Iceman24's Avatar
Iceman24
No...you either have an exhaust leak, or wrong tune...time to troubleshoot. Did you use new exhaust gaskets & torque the exhaust flange bolts to spec..??
Old Jul 1, 2012 | 10:33 PM
Johncarneiro
Stage II
I did use the new gaskets, bit the power commander v was tuned from factory. Could the settings be off?
Old Jul 1, 2012 | 11:22 PM
Fastrider124's Avatar
Fastrider124
Backfiring, popping thru the exhaust are both signs of lean mixtures. Take it to a tuner, have it dialed in. Thats after you confirm intake and exhaust are truly sealed up.
Factory maps are only good to get close enough to run the engine, they need a dyno tune to adjust final settings Fastrider124
aaronmcb80
Nov 14, 2016 04:10 PM
ib5150
Apr 6, 2013 11:39 AM
NCtaxguy
Mar 23, 2010 07:51 PM
ATC2
Sep 22, 2008 10:35 PM
WARG
Mar 11, 2006 08:19 PM
