Help woth 1340 softail prob please
Old Jul 2, 2012 | 01:18 PM
twills99's Avatar
twills99
2nd Gear
Default Help woth 1340 softail prob please
Hi guys,
Imhave a 98 softail custom, with Mikuni 42 carb. After a few months of non ise, I have had it out over the last few days, but it seems to have a fuelling problem. All os fine at low revs, but when the throttle is fully opened the engine dies, stops firing for a few seconds and then comes back to life. The problem is more frequent in higher gears. Also the engine seems to lack power at thentop end. Have checked plugs and filter, and it ran beautifully when I last used it a few months ago. Any suggestions very welcome as to the cause please.
Thx
Tim
Old Jul 2, 2012 | 06:43 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Only a suggestion, but you may need to remove your carb, and have a good look inside to insure all is functioning correctly.
Scott
Old Jul 2, 2012 | 08:40 PM
95custmz's Avatar
95custmz
This might sound crazy but my '95 was doing same thing & it turned out to be the battery. Had a dead cell, which caused the bike to "chug" like it was running ouy of fuel. When you test the battery, do a load test on it.
Old Jul 2, 2012 | 11:21 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
Disassemble your carb (including the jets, accelerator pump and float) and use compressed air to blow out ever orifice.
If you're not sure of how to set the float have someone set it for you.
If you haven't replaced the spark plugs recently you should do that first.
A weak battery is a possibility as is a loose ground cable (check at battery and frame).
Old Jul 3, 2012 | 04:01 AM
twills99's Avatar
twills99
2nd Gear
Thanks for all the suggestions. Imhave checked the battery, which is OK, so it looks like I will have to put some time aside and ge the carb off :-(
Cheers.......
Old Jul 3, 2012 | 05:33 PM
ajayrk's Avatar
ajayrk
Carb bowl dried out, ethanol crap now stuck in main jet and emulsion tube. As above, clean it well.
Old Jul 6, 2012 | 12:58 PM
lieutenant G's Avatar
lieutenant G
x2, soak, clean blow with compressor
Old Jul 6, 2012 | 01:03 PM
tazzzman's Avatar
tazzzman
I agree... carb clean and dump your gas, flush your tank and put in fresh. May need to check and clean your pepcock screen as well. Good luck
Old Jul 6, 2012 | 08:32 PM
djl's Avatar
djl
There ya go!
Old Jul 8, 2012 | 03:26 AM
twills99's Avatar
twills99
2nd Gear
Thanks guys! Just a quick update....Removed float drain and main jet. Dirt in the main jet. Thouough clean and all is back to its amazing normal! Thanks to all for the invaluable,help :-)
Great site!
wjc1947
Feb 8, 2018 12:09 PM
jimmy1340
Carburetor Related
May 31, 2015 06:18 AM
jauslong
Oct 22, 2012 08:32 AM
Pissdrunktbone66
Ironhead
Oct 4, 2012 08:15 PM
sammer4u
May 27, 2011 10:27 AM
