Running Rich
Old Apr 20, 2013 | 04:52 PM
run_ride_hide's Avatar
run_ride_hide
6th Gear
Default Running Rich
I have a 93 Fatboy that was previously put out to pasture. Its owner was a good buddy of mine who passed last April and left this Fatboy to me.
I have been working on it off an on since last May. I put rings in it (30 over), had the heads and valves worked, rebuilt the carb, cleaned and coated the inside of the gas tanks, new started switch, new coils (it has two single fire Dyna 5 ohm coils with a Dyna S ignition), new plugs, and other cosmetic stuff.
Anyway, when I got the engine back together it ran rich. I checked for intake leaks and have re-jetted the carb six ways from Sunday and it still is running rich. It runs best with the jets that were in it when I got it (48 & 190). I have tried 45 and 46 with no luck (doesn’t run good). It is loud and I’m starting to wonder if the problem may be the exhaust being too open. No matter what way I jet the carb the idle screw doesn’t have much affect when moved. I am to the end of any think I can think of to change and I hate to get this close to the finish line and have to take it to the shop. Looking for thoughts about what the issue might be. Thanks
Old Apr 20, 2013 | 05:19 PM
checkers's Avatar
checkers
An intake leak above the throttle plates would create a lean condition. With motor cold, start and idle, spray WD 40 around intake tubes and avoid air intake. if there is a leak it will effect the idle. If rich fuel mixture at idle the float level could be set wrong and fuel is spilling into throttle bore. Ethynol gas may have been left to set in the carb and ruined it inside, may have to replace. What do the spark plugs look like? Does it blow black smoke? Worse at idle? If exhaust is too free flowing it will cause a lean condition, not rich. Are the valves set right, have you static timed the engine? Is there a good spark? possible coil or wire
Old Apr 20, 2013 | 08:26 PM
run_ride_hide
6th Gear
Yes, it does have some black smoke at idle, but very little. I have new coils (just bought) and while I didn't static time I did move the ignition adjustment some to see if that would help and couldn't see that it did, but timing could be the issue. Timing is set like it was when I got it. The plugs are burning black (rich). I put a kit in the carb and nothing internal looked damaged. It starts and runs great when you are accelerating, only issue is at a cruise, which made me think I needed to go one size smaller on the 48 jet to a 46, but that made it run worse. Run it too long and the plugs turn black and foul.
Old Apr 20, 2013 | 09:45 PM
chuckw2's Avatar
chuckw2
... No matter what way I jet the carb the idle screw doesn’t have much affect when moved....
I had this situation, the vacuum line from the vapor canister to the carb was left open when a po removed the canister. This made a lean condition ie vacuum leak, not rich but maybe worth checking.
Old Apr 21, 2013 | 07:04 AM
checkers's Avatar
checkers
It sounds like a float adjustment to me, or internal carb issue where idle circuit in carb may be pulling fuel from the intermediate or high speed circuit. It should run on the jets that were in it, I assume your plugs and wires are Harley stock and new. Make sure your choke plate is staying open under throttle.
Old Apr 21, 2013 | 06:32 PM
run_ride_hide
6th Gear
Thanks for the information so far. I took great care when I put the kit in the carb to get the float within the measurements called out in the manual so I don't believe it is float adjustment. I soaked the carb twice in carb cleaner and it didn't look very dirty when I first disassembled. It certainly acts like it has a carb issue so I may replace. Couple of things I'm a little unsure of 1) It has VOES that I don't think was wired up when I got it. There was a single wire with no connector on it that wasn't attached. The color of the wire matches what the manual shows going to the VOES so I put a connector on it and hooked it up. I checked the switch by sucking on it and it seems to work okay. 2) I adjusted the push rods per a YouTube video I found where you set at the midpoint of the lifter travel counting nut flats; I think I got it right, but since I have never done it I'm a little unsure. I think the static timing is a good thing for me to do next, but I'm a little unclear on how it is done; can a normal car timing light be used or do you need some other kind of light. Thanks again!
tyallen9
May 16, 2020 01:51 AM
worstdayever
Carburetor Related
Sep 26, 2018 09:18 AM
BigMESA
Carburetor Related
13
Jan 3, 2017 05:10 PM
gpaxtell
Ironhead
13
Jun 22, 2009 07:05 AM
DeputyDog605
Apr 25, 2007 08:04 PM
