Twin cam wrist pin clip tool
Old Jun 27, 2013 | 04:33 PM
46u's Avatar
46u
Default Twin cam wrist pin clip tool
Does any one know why the wrist pin clip tool Drag sells that looks just like the Harley tool says not recommend for forged pistons? I cannot find the manufactures web site to ask them. I would think it would be OK to use on any piston with the dimple. I have some forged pistons to install and would like to know why it says not recommend for forged pistons.
Thanks
Jeff
Old Jun 28, 2013 | 11:13 AM
djl's Avatar
djl
Call Drag.
Old Jun 28, 2013 | 06:51 PM
46u's Avatar
46u
Originally Posted by djl
Call Drag.
Unless you are a dealer with them they will not give any help. Thanks for trying.
Old Jun 28, 2013 | 08:40 PM
djl's Avatar
djl
Not sure why you think you need that tool. You can go caveman and install the wrist pin locks without a special tool. Check out the link.
http://harleytechtalk.org/htt/index....ic,1084.0.html
Old Jun 28, 2013 | 09:02 PM
46u's Avatar
46u
I know and I have done it with out it. But it sure makes things easier and got a very good deal on it. All I would like to know is why they say in the Drag book not recommend for forged pistons.
Thanks
Jeff
Old Jun 28, 2013 | 09:03 PM
soft 02's Avatar
soft 02
Copper coupling trick works good but I just use my fingers and a customized screwdriver.
Old Jun 28, 2013 | 09:09 PM
46u's Avatar
46u
Yes I have done them in the past by hand but the tool works much better. I all ready have the tool which I got a really good deal on it and makes things so much easier. I am not only a gear head but a tool head as I do so much motor work. What I would like to know is why Drag has not recommend for forged pistons. If the piston has the recess in it I do not see why it would not work on forged pistons.
Thanks
Jeff
Old Jun 29, 2013 | 02:06 AM
Tat2u's Avatar
Tat2u
if it fits I would just use it. what harm could it do, its just a tool fitting a small clip. let us know how you get on. that's one tool I wouldn't mind getting one day, I just used a small screwdriver but nothing like having the proper gear
Old Jun 29, 2013 | 08:15 AM
46u's Avatar
46u
I agree I do not see why it would not work. I have as much or more in my special HD tools as I do my 02 Ultra I bought new and my HD sidecar. I have been collecting for for 42 years. LOL
Thanks
Jeff
Old Jun 29, 2013 | 09:50 AM
wurk_truk's Avatar
wurk_truk
I think the hole in the wrist pin is a different size when it comes to forged or cast? or the outer diameter of the pin is different.
I use MY clip tool whenever needed. I have found that sometimes, with the forged, the tool will NOT pull the circlips off, but have always had good luck installing any circlip onto the piston using the tool.
I also thought this 'don't use' crap was really based upon 06 back and 07 up and not forged-vs-cast.
