Too Lean?
Old Mar 5, 2007 | 02:40 PM
Rocketscntst's Avatar
Rocketscntst
Stage II
Default Too Lean?
I just took delivery of my 2007 deuce. My near term plans are toinstall a Hypercharger Pro-R air cleaner, V&H big radius pipes, followed by a re-map (Power Commander or similar). Since I will likely do this over a few month period; if I install the hyper charger now without a re-map will my new bike run too lean since it will be breathing at least a little eassier?
Thanks in advance for the advice.
Old Mar 6, 2007 | 10:54 PM
Retired_Ted's Avatar
Retired_Ted
Default RE: Too Lean?
No way to know unless you have it checked - chances are, it will run a little leaner - personally, I'd do the exhaust at the same time - you may actually hurt your performance by not allowing more airflow out of the exhaust while forcing more into the engine. Do them both and then go for the dyno - a power commander will probably be needed if you need to make adjustments to the map.
Old Mar 9, 2007 | 12:29 PM
kwas's Avatar
kwas
If you go with any change in AC which allows more air flow, it will cause it to run leaner. If you change the AC, your best bet is to do the EFI (PCIII-SERT) management at the same time.
Old Mar 9, 2007 | 07:53 PM
electaRICK's Avatar
electaRICK
suck,bang,blow
its a simple process
but
dam if I know!!! ;lol
Old Mar 9, 2007 | 08:09 PM
glide's Avatar
glide
ORIGINAL: Rocketscntst
It will be too lean with the intakeopened upand the hypercharger really isn't the best selection for good performance.
Old Mar 11, 2007 | 12:05 AM
daconiam's Avatar
daconiam
Harley has a map for just the A/C change. They sell it as part of a "stage 1" in their catalog, getthe air cleaner and the map as one setup.... I had this done before I took delivery ofmy bike. Then you can change out the pipes later.
Or just can get all 3 (PCIII/, air cleaner and exhaust/slip-ons) as a package from from places at a discount.
kalamitty
Apr 13, 2012 12:42 AM
wolfman55
Dec 2, 2010 01:17 AM
Redbob 07
Apr 10, 2009 10:29 AM
SD Night Train
Mar 19, 2009 05:34 PM
SimonW
Oct 8, 2006 09:44 PM
