tc88b startup clunk
Old Oct 2, 2013 | 10:11 PM
the blob's Avatar
the blob
Default tc88b startup clunk
hello, ive got a new to me 2000 fatboy when i restart after a few hrs of sitting id does the startup clunk sound. Bike has 14,000 miles and a screaming eagle ign module. thats about all i know about the motor. Any ideas on why it clunks on start up?
Old Oct 3, 2013 | 11:58 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I'd start by checking the primary chain for proper running play, and also the check the compensating sprocket nut, insuring that it is tightened correctly, all per service manual specs.
Scott
Old Oct 3, 2013 | 12:58 PM
djl's Avatar
djl
Adding to Scott's post. The comp nut backing off is a common issue with the early models. If you should find that the comp nut has backed off, remove the nut and have about .030" milled from the end of the nut before re-installing.
Old Oct 3, 2013 | 03:50 PM
the blob's Avatar
the blob
Thanks all for the replys. I will get the primary apart and take a look!
SummitRK
13
Apr 27, 2020 07:56 PM
txphatboy
Aug 28, 2011 09:38 AM
scubaharley
Jun 17, 2011 08:02 AM
TRVSDAD
Jul 28, 2010 11:38 AM
BlackFLHR
Oct 22, 2009 09:28 AM
