Valve spring replacement
Old Oct 21, 2013 | 06:53 AM
Lamy1's Avatar
Lamy1
Default Valve spring replacement
Hi guys can anyone help me with this issue, can I replaced the valve springs without removing the heads or is the frame in the way, I want to upgrade the springs to a higher lift.
Any help appreciated.
Thanks
Old Oct 21, 2013 | 07:34 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
While Goodson does offer a tool to allow that to be done in the bike, you may need to double check the valve to valve, and valve to piston clearence if stepping up into a large cam, requiring the removal of the heads.
Scott
Old Oct 21, 2013 | 08:05 AM
prodrag1320's Avatar
prodrag1320
once you get the r. boxes off,pipes & induction system isn't a big deal to remove to take the heads off.like scott said,more to check than just coil bind
Old Oct 21, 2013 | 08:46 AM
Uncle Larry's Avatar
Uncle Larry
"Hillsidecycle" has given you good info ... and the cost of the tool from Goodson http://www.goodson.com/Installation_Tools/ would more than pay for you gasket set and other incidentals needed, If you're changing springs there must be a reason ... why not pop off the heads and get a good look at the heads? ... Just my.02 cents worth.
Old Oct 21, 2013 | 09:44 AM
Lamy1's Avatar
Lamy1
Thanks guys great info, but I have spoken to the guys at S&S , I want to install 583 easy start cams and have been told that if the valve stem diameter is 5/16'' I will need to change the springs, but if the valve stem diameter is 7mm I will not have to change the valve springs doe's anyone out there have any idea what size diameter the stems are likely to be before I remove.
Thanks guys and have a great day ride safe.
Old Oct 21, 2013 | 01:49 PM
prodrag1320
`05 up uses 7mm valves,springs are good to .600
Old Oct 21, 2013 | 02:49 PM
Jack the Machinist's Avatar
Jack the Machinist
6th Gear
Originally Posted by Lamy1
Thanks guys great info, but I have spoken to the guys at S&S , I want to install 583 easy start cams and have been told that if the valve stem diameter is 5/16'' I will need to change the springs, but if the valve stem diameter is 7mm I will not have to change the valve springs.
If you have 5/16 valve stems, it's not just the springs, you also need to shorten the guides, or the retainer will bash into them. This is definitely a machine shop operation.
Old Oct 21, 2013 | 05:01 PM
46u's Avatar
46u
Would help if we new what cams and what year bike.
Old Oct 21, 2013 | 06:43 PM
Lamy1's Avatar
Lamy1
Thanks for the help guys, love the comment by Jack the Machinist, if I was in the USA I would bring my toy to you mate.
Cheers guy's
Old Oct 24, 2013 | 11:29 AM
Jack the Machinist
6th Gear
Thanks for the compliment. Good luck with your project.
Guythunder
Engine Mechanical Topics
May 19, 2024 12:03 PM
tweaked02
Sep 12, 2017 05:00 AM
homiegfunk53
EVO
Jul 31, 2013 05:33 PM
HarleyReece
EVO
19
Jul 30, 2012 10:46 AM
ridesegc04
Jul 20, 2008 07:15 PM
