Do You really Need?
Old Mar 14, 2007 | 08:56 PM
Littleshack's Avatar
Littleshack
Default Do You really Need?
Would a Torque Bar be need on a Twim Cam or not? Not a Torque Wrench.
This would be Torque Arm, Rod, Plate to go from engine to trans on a twincam.
Old Mar 14, 2007 | 09:15 PM
glide's Avatar
glide
Default RE: Do You really Need?
Not needed on a TC, only on evo's
Old Mar 14, 2007 | 09:21 PM
Alien Spyder's Avatar
Alien Spyder
ORIGINAL: glide
Really?? I just got done watching a "Fix My Hog" video last night and they stressed that everything on a TC88 should be torqued to spec's provided in the H-D Manual.
I just bought an inner primary cover and it's got all the torque specs in big bold print.
I just got done surfin Ebay for torque wrenches............
Old Mar 14, 2007 | 09:31 PM
glide's Avatar
glide
ORIGINAL: Alien Spyder
ORIGINAL: glide
I took the origional post that stated "Would a Torque Bar be need on a Twim Cam or not? " as a torque arm as in "Carlini" torque arm that braces the trans and the engine as a unit for rigidity. If it indeed meant a torque wrench and not a bar, then I agree that pretty much every bolt should be torqued with a "Torque wrench" not only on an evo but a twin cam also.
Old Mar 14, 2007 | 09:59 PM
Arcane's Avatar
Arcane
The HD shop manual lists torque values for almost every bolt and nut on the Twin Cam 88 engine and the chassis. Some individuals may be able to tighten to the recommended torque specifications by feel, but I can not. With so much aluminum being used in the engine I would rather use a Torque wrench and lookup the recommended values than end up stripping the threads, or having critical parts falling off while traveling down the Interstate at 70 -80 MPH.
Arcane
Old Mar 14, 2007 | 11:15 PM
Littleshack
Im am talking about Torque Bar (Plate) "Carlini" I think Harley makes one too. \
I am NOT talking about a Torque Wrench! But thanks to all that replyed
Old Mar 14, 2007 | 11:51 PM
Zyklon's Avatar
Zyklon
Hello Littleshack,
I do not know about the older model Twin Cams, but the 06 and 07 Dyna Glide models have the engine and transmission bolted together so that they form a single unit. If you are worried about flex or misalignment I would doubt that there will be enough to warrant use of a brace or Torque bar. It is probably one of the most ridged engine / transmission configurations that HD has ever had.
Zyklon
Old Mar 15, 2007 | 04:53 PM
Littleshack
This would be a 2003 Twin Cam 88 punched out to a 95 on a Fatboy
Alien Spyder
Feb 27, 2013 11:57 AM
20Sporty06
Sep 15, 2010 07:56 PM
CBNDSDADDY
Jan 11, 2010 06:31 PM
huffhuff
May 13, 2008 02:51 PM
RanD
Apr 18, 2007 06:52 PM
