Engine build
Old Dec 9, 2013 | 05:44 PM
Gunny20's Avatar
Gunny20
Default Engine build
Looking for expert feedback please.
currently -2000 roadking 95" kit with 203 cam and R&B 2-1 blackhole exhaust.
Going to have SE CNC heads installed , 37g cam with .040 gasket.(Recommended by dealer)
I want low end torque for 2 up riding.
Will this combo work ?
Old Dec 9, 2013 | 06:03 PM
prodrag1320's Avatar
prodrag1320
that wouldn't be a bad mid range RPM build,but for what your looking for,have your heads done,(scrap the SE head idea),go with S&S .583 cams,set the compression @ 9.8-1,use .030 headgaskets (if you told the guy you wanted a low TQ build,you may want to look for another dealer)
Old Dec 9, 2013 | 06:32 PM
Gunny20's Avatar
Gunny20
Originally Posted by prodrag1320
that wouldn't be a bad mid range rpm build,but for what your looking for,have your heads done,(scrap the se head idea),go with s&s .583 cams,set the compression @ 9.8-1,use .030 headgaskets (if you told the guy you wanted a low tq build,you may want to look for another dealer)
much appreciated
Old Dec 9, 2013 | 08:46 PM
micalaut's Avatar
micalaut
Take ProDrag's advice, he did my heads and recommended a different cam than a 203, my bike is quicker, faster, smoother, cooler running and no loss of gas mileage.
Old Dec 9, 2013 | 08:51 PM
HD Bobber's Avatar
HD Bobber
+1 on the above comments! Have your heads done and scrape the idea of a cookie cutter setup. Customize something 100% to your riding style.....will be cheaper than buying Screamin Eagle setup & will yield better results. Having your heads reworked and they will flow way better than the stock SE's will.
Old Dec 10, 2013 | 04:29 AM
Gunny20's Avatar
Gunny20
Default Micalaut
Thanks
Which cam did you use ?
Old Dec 10, 2013 | 10:25 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Another cam that'll deliver VERY well in the low and mid range power band, set at 9.6 cr is an Andrews 26.
We have clients that we've set them up with those, 98", and our Stage I Head.
Many push off 108-110 ft/lbs, right in the range where a touring bike can use it.
Scott
Old Dec 10, 2013 | 11:20 AM
Kingofcubes's Avatar
Kingofcubes
No, those SE heads are high rpm horse power heads, I like the 37 cam and the stock heads opened up . This is a cam you can build with, more inches, .030" head gaskets, more compression, and installing the SE 1.7 rocker arms on the intakes will give you more low end torque and power.
Old Dec 10, 2013 | 04:02 PM
micalaut's Avatar
micalaut
I used the Andrews 26 with compression set at 9.6 , exhaust valve opened up a bit, Cometic .030 head gasket, I too have a 95" kit in a 2006 touring bike. My goals were same as yours (2 up touring), really noticeable improvement. Only negative is a little slower cranking but starts fine. Only regret was that that I didn't do a 98" kit instead of 95". I'm no engine builder but I would expect that they would tell you the Andrews 37 in a 95" touring bike might not pull where you want it to pull.
Old Dec 10, 2013 | 06:02 PM
Gunny20's Avatar
Gunny20
I really appreciate ALL the feedback !!!
andybloom
Sep 28, 2013 01:23 AM
gpp
Jan 3, 2008 06:07 AM
Papamte
Nov 20, 2007 01:44 PM
mp99
Oct 2, 2007 08:45 AM
rollover
Jan 1, 2007 07:51 PM
