Flange torque
Old Apr 6, 2007 | 09:53 AM
07flstc's Avatar
07flstc
Default Flange torque
What is the exhaust flange nuts torque for a 2007 Heritage Softail Thanks in advance
Old Apr 6, 2007 | 10:22 PM
djkolp's Avatar
djkolp
Default RE: Flange torque
ORIGINAL: 07flstc
Here are the torque instructions from the 2007 service manual for FXST/FLSTC/FXSTB/FXSTC bikes. Note thatTorque isin-lbs.
1. Tighten nuts at cylinder heads as follows:
a. Install upper nut and tighten finger tight.
b. Install lower nut and tighten to 9-18 in-lbs (1.0-2.0 Nm)
c. Tighten upper nut to 100-120 in-lbs (11.3-13.6 Nm)
d. Tighten lower nut to 100-120 in-lbs (11.3-13.6 Nm)
DJK
Old Apr 10, 2007 | 04:41 PM
cwilks's Avatar
cwilks
You actually use a torq wrench onexhaust nuts??????????????????
Old Apr 11, 2007 | 11:02 PM
Retired_Ted's Avatar
Retired_Ted
I also torque them and check the torque at least twice after an installation.
Old May 11, 2007 | 10:26 AM
07flstc's Avatar
07flstc
djkolp , THANKYOU !!! worked out good !
Old May 12, 2007 | 10:40 PM
djkolp's Avatar
djkolp
ORIGINAL: 07flstc
My pleasure. Glad it worked outfor you. I'm amazed that some peopleon this forumfind using a torque wrench an insult to their intelligence. Experienced mechanics might be able to get it close to spec, but I can't. I don't turn a wrench for a living, and I'm quite happy taking the time to do it right. Not too tight, not too loose. Oh,and never having to ask what to do about sheared bolt or stripped screw. Well, so far anyway. Cheers.
DJK
Old Dec 2, 2008 | 03:06 AM
rockon's Avatar
rockon
Was working on the exhaust tonight, and I don't know what it is, but all 4 flange nuts are stripping, and I can't get them off! How do I fix this?
drinktothat421
Jun 10, 2016 10:53 PM
Sliver1
Jan 17, 2014 03:12 PM
GymChamp
Nov 21, 2009 02:52 AM
rzbigdog
Jan 8, 2008 09:11 PM
bobby5
Mar 11, 2007 12:34 PM
