Another serial number problem
Old Mar 12, 2020 | 04:53 PM
tasturbo86's Avatar
tasturbo86
Default Another serial number problem
I bought a 40's Flathead (I think) with a rusty frame and no engine serial number. More on the frame later.
Maybe the engine serial number was removed, but if so, it was done well, as the area still has a normal appearance (In my humble opinion).
To make things worse, the belly numbers are corroded, and the FIRST digit, which should be the first number of the year of manufacture, is very faint.
I think that first number is a 4. Any ideas?
Note that there is still some olive drab on the case, which would be normal for a WLA engine.
It was rumored that this was a bike that never made it to WWII and might have been a parts bike.
Old Mar 12, 2020 | 05:04 PM
touchdown's Avatar
touchdown
Maybe never numbered Poor some acid on it
Old Mar 12, 2020 | 05:15 PM
johnjzjz's Avatar
johnjzjz
to me it appears to have file marks and the overall thickness is thin
many WLA engines made with out the rest of the machine were not stamped with any numbers
Old Mar 13, 2020 | 12:05 AM
Speeding Big Twin's Avatar
Speeding Big Twin
Originally Posted by tasturbo86
To make things worse, the belly numbers are corroded, and the FIRST digit, which should be the first number of the year of manufacture, is very faint. I think that first number is a 4. Any ideas?
It may indeed be 4 and the second number may be 5. Below is an example for comparison and you'll notice the 4 has an open back (as opposed to an open top). Also notice the 4 is sans serif. This type of sans serif, open-back 4 was used in the BN decade position for 1941–46.
On the left case you may find casting number 112-392 and a casting date code consisting of a letter and a number. Hard to be certain when the left case was cast but I suspect around April 1945 and if so then the code would be D and 5 (spaced). What have you got?
D equals April. And on this occasion, because the characters are spaced, 5 indicates 1945.
NB: if those two characters were unspaced (D5) then the code would usually indicate casting in April 1950. However, date code character spacing is something that needs to be examined piece by piece because the rules are not always the same and sometimes there are exceptions to what at first seem like rules.
Re the serial number boss, it appears to have some marks but it’s hard to say what happened. Maybe clean it and post another picture? Also as John said, many WLA engines made without the rest of the machine were not stamped with a serial number.
Eric
Old Mar 13, 2020 | 07:01 AM
Architect's Avatar
Architect
As stated, many motors were assembled for surplus, not uncommon to have a WLA motor with no VIN at all. Also common that they have weird looking VIN's from Military issue or even local State DMV's. Overall, I would rather have it with no numbers then some weird *** numbers. But it is hard to say for sure with current pics.
There is some kind of acid test that the Police use to see if an older VIN # has been removed, all I know about it. Maybe some of the fellas here can tell you how to do it. It was used to find the original numbers on a pad, under a new set. Good luck.
Old Mar 13, 2020 | 07:41 AM
tasturbo86's Avatar
tasturbo86
Eric,
Here is the picture of the left side of the case. C 5
Looks like it would be March 1945?
I guess we have a birthday this month. Only 75 years old! Got me by 4 years!
Old Mar 13, 2020 | 07:53 AM
tasturbo86's Avatar
tasturbo86
Architect,
I looked around for acid tests on serial numbers.
I saw two options for aluminum:
- heat the area around the number
- apply sodium hydroxide to the area. This happens to be the main ingredient in Draino.
I'm going to give it a try today.
It would be nice to have a number to make it easier to register the bike in Georgia.
I have a different thread here for the frame identification to see if it is the same vintage. I will attach pics of numbers I have found.
terry
Old Mar 13, 2020 | 07:58 AM
Architect's Avatar
Architect
Casting code matches belly numbers, that is a real good start.
Old Mar 13, 2020 | 05:52 PM
tasturbo86's Avatar
tasturbo86
I tried acid and heat to find a serial number on the 'pad' between the cylinders with no luck.
With help from Architect and Speeding Big Twin:
The belly numbers look like it was a 1945 production engine
I will accept the likely fact that the engine may have never been married to this, or any frame.
For the frame identification, I have posted a separate thread:
https://www.hdforums.com/forum/flath...-navy-wla.html
I have attached pictures of all the numbers I could find to that thread.
Any help dating the frame would be appreciated.
terry
Old Mar 14, 2020 | 12:17 AM
Speeding Big Twin
Eric,
Yes. In this instance C 5 (spaced) indicates the case was cast in March 1945 and the BNs are consistent with that.
Below is another example of C 5 (spaced) and you’ll also notice what appears to be the number 4. I think your case has 4 stamped on it too but I don’t know exactly what it indicates and my best guess is that it was done by an inspector. Another possible inspector marking in my photo is 2X which your case may or may not have.
Eric
