So on these 45 flathead Harley’s , or any Harley what is the recommended usage on head bolts?
I know bolts cans stretch, so how times is it okay or not okay to reuse? Nothing my sucks more than a broken head bolt.
The original bolts was grade 8 or 9 from the WW2 issue - 10 of todays head bolts are not as strong as one of those - from use and the amount of engine rebuilds i have seen the wrench head rounded ( a bit ) but the bolt and threads were fine
Ok got that, but is there any norm for the number of times they can be reused ? Or just used them until the bolt head starts to round off?
They're not torque to yield ( TTY) so IMO if they look in good shape they should be fine. If you suspect any, maybe measure the lengths with a dial caliper ( from under the head to the other end) and make sure they are all around the same length.
Now that makes sense. After wenching on cars for 40 years I was thinking it’s got to the same.
But being new to working old a Harley one can never assume anything.
Thanks 👍everyone for the feed back, as mommy always said many brains make for better success!!!
