1941 WL battery question
Old Nov 23, 2008 | 11:29 PM
kngkong's Avatar
kngkong
4th Gear
Default 1941 WL battery question
Hey,
Ok, Im new to this. Can someone point me in the right direction for a battery for this here bike.
Appreciate the help...gonna need it
I bought it from someone who never tried to start it. He had bought it from someone mid restoration without knowing how much had been touched in the engine. He thought maybe it could start but didnt want to try without breaking the engine down to see the state of its insides. What do you think? Should i throw some gas in it and give it a try or break it down?
Other than that the bike is almost 100% complete and turns over easily.
Appreciate your help
Cheers
John
1941 WL
Old Nov 24, 2008 | 02:38 PM
d_slat's Avatar
d_slat
I don't think i'd break it down right away, i'd make sure it has fresh oil and give it a try. If I were you i'd clean out the carb first, but if it turns over ok by hand, give it a shot. As far as the battery is concerned, ?????
Old Nov 24, 2008 | 05:24 PM
kngkong's Avatar
kngkong
4th Gear
Thanks for your reply. Appreciate your help.
In the meantime can i use any old 6V battery? Its all the same eh?
Old Nov 25, 2008 | 07:45 PM
mustasz's Avatar
mustasz
You can use almost any 6v battery,as long as it's not too old,has to keep the charge,more than 6v between the posts,otherwise you'll have problems to start the bike. I sometimes connected small motorcycle charger to the battery,while starting bike
Old Nov 25, 2008 | 10:24 PM
kngkong's Avatar
kngkong
4th Gear
does switching to a 12V system alleviate these problems?
Old Nov 27, 2008 | 11:35 AM
FilthyLucre's Avatar
FilthyLucre
J&P Carries the proper size battery, Retail about 90.00. You maybe able to get your local independent shop to order you one from a different supplier for a lot less. Switching to 12 volt will not change anything as far as starting. Harley switched to 12 volt when they went to electric start. If you have a good 6 volt generator and regulator just keep it 6 volt. If your generator and regulator are bad than it is a matter of whether you want to keep the bike original or not.
Old Nov 27, 2008 | 04:47 PM
kngkong's Avatar
kngkong
4th Gear
I see. Ok. Ill stick with the 6v for a while
Old Nov 29, 2008 | 02:31 PM
matt45's Avatar
matt45
Except if you ride only during night time, better to keep the 6volt system, at least you are sure that you can keep safe your overall electrical system.. I keep 6 volt on mine WLA and never got any trouble to start.. and any trouble at all..
Old Nov 29, 2008 | 05:30 PM
sqdealgeorge's Avatar
sqdealgeorge
Love the bike picture If you got at least 40 psig comp / spark/ and gas from the carb Party on
Old Nov 29, 2008 | 06:50 PM
kngkong's Avatar
kngkong
4th Gear
Thanks George, nice and simple. Ill let you know how it goes. Ill have her home in about a week, then the fun begins.
