Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Streetglide Specials !
Old Jan 17, 2015 | 12:26 PM
sbeamer's Avatar
sbeamer
Exclamation Streetglide Specials !
If anyone with a new Rushmore Streetglide Special, and you are considering up-grading your shocks, know this! Your shocks are not the same length from side to side! I'm working on this Right Now!! In case you care.
Old Jan 19, 2015 | 01:21 PM
Delta's Avatar
Delta
I thought this was the case too when I was installing the 13" Premium Hand Adjustable shocks on my Ultra. When I did the install I had to remove the left side muffler hanger bolts so I could have clearance to the lower shock mounting bolt. I did not do this to the right side. When I went to install the right side shock it appeared the shock was a bit too long. When I removed the hanger bolts, it allowed the swingarm to move more freely.
Could this be the case with your situation?
Old Jan 20, 2015 | 07:49 PM
sbeamer's Avatar
sbeamer
No. I have the 2 shocks off the bike. While they were laying on the bench, I noticed 1 was longer than the other! About 5/16" difference! My new shocks are the same length. I've had a lot of shocks off for various reasons in the past, but on the 09 & newer, it's always been air shocks. This is the first one with springs.
WMX124
Oct 19, 2016 08:34 AM
blj184
Oct 31, 2015 09:13 PM
sbeamer
2014-2024 Touring Models
Jan 19, 2015 07:02 PM
Midgard
Jan 23, 2013 05:44 PM
retxpres
Nov 26, 2012 08:41 AM
