Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Adjusting legend revo-A shocks
Old Jun 18, 2016 | 08:57 AM
Bobbycaz's Avatar
Bobbycaz
4th Gear
Default Adjusting legend revo-A shocks
Ok so I got a set of legend shocks for my street bob. They are great shocks the only problem is when they have been on a certain preload setting for a little while they are really hard to get spinning again on the threads, then not so bad after a few turns for the most parts. So has anyone use or put some sort of oil on the threads for the pre load adjustments. Thanks
Old Jun 19, 2016 | 01:10 PM
grbrown's Avatar
grbrown
Have you tried jacking the rear up a little, to take the weight of the bike off the rear wheel? That should in turn reduce the load on the shocks and may make resetting preload a little easier. Otherwise use something like WD40, to help the threads, I don't see any problem with that. Having got them moving you could clean the threads and use a little weather-resistant grease on them, for future use.
Old Jul 3, 2016 | 04:54 AM
beammeup's Avatar
beammeup
having Revo A's, I know the situation.
I'd wash the threads with soapy water or a diluted Simple Green or similar and comb the threads with a brush then rinse. I wouldn't leave anything on the threads that dirt or oil might cling to.
Cleaning is important for any threaded shock, but for these Revo's, how you turn them is important too. Turn from the top of the shock and not the bottom and buy a pair of gloves from Harbor Freight or similar that have a rough rubberized palm. Excellent for gripping the threads to turn them especially if he rear tire is on the ground.
chief1600
Sep 4, 2017 11:58 PM
2013superglideseattle
Feb 2, 2016 05:51 PM
showlowzook
Mar 25, 2015 01:12 PM
rambo1313
Jul 16, 2007 09:04 AM
medic434
Jul 12, 2007 03:34 PM
