front ABS brakes
Edit
OP I did a quick look at your profile to see what year and model bike you have. Are you having trouble with the 2011 Touring bike you got after it was in a flood? If so, I'd recommend switching to organic pads in the front as they don't have as much initial bite as metal sintered. Chasing electrical issues on any flooded vehicle is going to get expensive quick. I'd get it to go down the road and call it good.
if it is the sensor that reads the reluctor ring, it can not make the brakes lock in itself, all it does is supply a tooth count/frequency to the bcm which determines wheel speed and determines slip. just pull the sensor connector, a code will ensue but the machine will still roll, the same if it goes bad. the bcm has windows or parameters which must be met or it will fault the sensor. i would look elsewhere since having a machine just lock up is a very heavy safety issue which can cost hd millions in legal issues.
After you soldered the front wheel sensor the front brakes operates as a non abs bike, (ie, front brake operates , but no abs with hard braking) , but the rear brake still activates the abs if braking hard ???... That is strange ,, as I was of the opinion that if a fault occurs within the abs system , (ie, abs light on solid and a fault code showing), the brakes, (front and rear), should default and operate as normal ,, (as in a non abs bike),, , but without abs.... If this is not correct, I will stand corrected ....
First off,, before you messed with the front wheel sensor, was the abs light, (on dash), flickering on start up, and then going off while riding, (which is normal) ???
Now,, what is happening to the abs light on the dash ???
Now,, what if any fault codes are showing regarding the abs system ??? If you dont know how to do this for your model bike,, google is your friend..
Whatever your problem is ,,, I would not have tried to repair a damaged wheel sensor , (other than a broken/pinched wire in the wiring loom)...
