Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Pulsing front brake lever
Old Apr 29, 2020 | 07:28 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Originally Posted by dawg
Do you have ABS?
Sorry, I should have mentioned no ABS.
Old Apr 29, 2020 | 08:07 AM
bustert's Avatar
bustert
warped rotors will cause a sensation in the steering. they would have to be way out to cause pulsation due to the fact that the pads are riding on the surface, but the first mentioned would be very noticeable.
pulsation is caused by friction coefficient diff on the rotor surface. pads slide nicely over the hard sport and grab on the softer spots. this will be very noticeable in the lever. what to look for is shinny or discoloration areas on the rotor surface. if so, must replace them. this type of defect happens in all metals.
Old Apr 29, 2020 | 08:22 AM
o/d's Avatar
o/d
Make sure both pistons in caliper are moving freely also.
if one piston is sticking it can result in pulsation in lever
Old Apr 29, 2020 | 08:58 AM
Hecklerboy's Avatar
Hecklerboy
The spongy feeling tells me you have air or moisture in your fluid which can cause your brakes to pulsate.
Change out the fluid first and see if that fixes the problem.
Bookie
Nov 18, 2019 05:28 PM
flynavy
May 21, 2015 09:26 PM
2wheels4ever
Wheels/Tires
Nov 12, 2013 10:34 AM
Charlie Fogg
Dec 22, 2012 07:44 PM
Paul G
13
Oct 9, 2012 05:35 PM
