Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Pulsing front brake lever
Old Apr 28, 2020 | 05:50 PM
Bubba Zanetti's Avatar
Bubba Zanetti
Default Pulsing front brake lever
09 Road King Classic with just a tick over 40k on the clock. Went for a ride today for the first time since February and noticed some pulsing and sponginess in the front brake lever and it feels like the brakes are grabbing then letting off just a little as I come to a stop. If I’m thinking correctly my rotors are likely warped. So I’m thinking it’s time for some new binder parts. Here’s my list I plan to order. Did I miss anything?
Left front brake rotor #44950-08
Right front brake rotor #44959-08
Front brake pads #41854-08 (x 2 sets)
Rear brake pads #41852-08B
New rear rotor 2 years ago and haven’t noticed any pulsing in the rear so I figured I can get by with just pads in the back.
Old Apr 28, 2020 | 05:52 PM
dawg's Avatar
dawg
Do you have ABS?
Old Apr 28, 2020 | 06:09 PM
Captain Chaos's Avatar
Captain Chaos
I've had rotors pulsate like that before from 'glazing' from certain pad compounds. A real hard stop from a high speed would actually clear them up.
I doubt that's your problem though, mine was a very aggressive compound on a spirtbike. Still, I'd want to try and measure run-out before I dropped the money for new rotors as that bill can add up QUICK.
Old Apr 28, 2020 | 06:23 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Yup, gotta agree with the Capt.
OP~ if you want to spend $$$ needlessly on new parts, then go ahead...
Old Apr 28, 2020 | 06:30 PM
Sparky here's Avatar
Sparky here
I was told that could be a sign of water in the fluid and that changing the fluid would correct the issue (information from dealership). Haven't changed fluid yet to see if it corrected the occasional pulsing.
Old Apr 28, 2020 | 06:31 PM
MURPHCC1's Avatar
MURPHCC1
Had it happen and yes it was warped rotors......MAKE SURE thats the problem first.
And get new rotor mounting bolts.
Old Apr 28, 2020 | 06:40 PM
RK4ME's Avatar
RK4ME
Try cleaning the rotors with brake parts cleaner and a mildly abrasive cleaning pad or 0000 steel wool, then do some fairly hard stops from highway speeds if your brakes aren't too far gone for that. The theory here is that the rotors may have been exposed to something that the area under the brake pads wasn't.
If you can elevate the bike and spin the front wheel, you can check for runout on the rotors.
Old Apr 28, 2020 | 06:46 PM
IBE's Avatar
IBE
just get a new set of rotors for the front and 2 sets of pads,, set for front / set for back. new fluid and that should take care of it. you got it should do the job
warped rotors will cause the brake handle to pulsate in and out. just as it would with your foot on a brake pedal, if in a car.
Old Apr 28, 2020 | 06:50 PM
LoneBone's Avatar
LoneBone
If your rotors are warped, when you hit the front brake you won't just feel sponginess in the lever, you'll feel a vibration or shimmy in the entire front end.
Rotors aren't astronomically expensive, but check the small stuff first....
Old Apr 28, 2020 | 06:55 PM
Tommy C's Avatar
Tommy C
Check the rotors for excessive runout with a dial indicator. It'll take all of the guesswork out of the equation.
