Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Lyndall Z pad break in ??
Old Aug 17, 2007 | 03:15 PM
MICHALISLARNACA's Avatar
MICHALISLARNACA
Default RE: Lyndall Z pad break in ??
I have been using Lyndall products for the past three years, on both my bikes. The one is FXDL 2001 and the other one is a FLSTF 2007.
The brake pads DO NOT need break in time ONLY if you use floating rotors. If you use STOCK then you need to bed them in for a couple of 100 miles. This is so because the stock rotors do not shift to embrace the pad and the pads to develop full surface contact need some wearing off. Also you need to be very care full with the pads if you ride at cold temps. The pads cool down very fast.
Old Oct 14, 2007 | 02:51 PM
flsts's Avatar
flsts
Sorry about reviving a older thread but I have a problem with my Lyndall pads. I just put new Z pads on the front of my Heritage Springer. I have them on the rear and have been using them for a while with no problem. The front brakes don't grab very well. Is this a symptom of needing break-in with stock rotors? I rode around my block to test everything before I did anything else. All low speed but I am not comfortable going fast with them the way they are now. Do I really have to ride a couple of hundred miles or is something wrong?
Old Oct 15, 2007 | 02:04 PM
jakazz's Avatar
jakazz
about locking up the rear....well not to be a jakass but you should start practicing panic stopping where you get almost all the braking effort out of your brakes. Cause if your locking the rear now Kiss ur **** in an emergency. You need to practice so you "know" exactly how far you can go without locking, then you get all your braking power.
Probably the most important area of moto riding is proper braking technique.
Old Oct 15, 2007 | 05:18 PM
FastHarley's Avatar
FastHarley
Former Sponsor
ORIGINAL: flsts
Problems? Give me a call or the person who bought them from and he or I will straighten you out. MY toll free # is 1-866-899-5962. the owner, Paul and everyone of his venders will try and solve your braking problems.
Old Oct 15, 2007 | 07:06 PM
flsts's Avatar
flsts
I found the break in procedure for the Gold pads and followed that. They work much better now. Thanks for all the offers to help. If I have any more problems I will call.
I now know where to go for my next set of pads. [sm=smiley20.gif]
garett742
Nov 30, 2015 11:54 PM
Olsen185
May 22, 2013 08:00 PM
grizzwold
EVO
Sep 4, 2011 08:08 AM
artz
Jun 27, 2010 08:39 AM
paguy
Jul 8, 2009 02:44 PM
