Brakes
Old Jul 8, 2009 | 12:04 PM
paguy's Avatar
paguy
Default Brakes
07 RKC. 16,000 miles. Service wth state inspect. 2 weeks ago. Started looking at calipers last night. Measured pads at about 1 mm. Spouse says dealer looked at them so they got to be OK.
Question, approximately, 16,000 within need to replace. How much usually cost for standard brake replace. Rear looks OK. Should I just go and replace all pads?
Old Jul 8, 2009 | 01:09 PM
jdreed520's Avatar
jdreed520
Just replace them........it is easy........
Old Jul 8, 2009 | 01:20 PM
jackja25's Avatar
jackja25
Yourself that is. Extremely easy. Will save mucho denara (sp)
Old Jul 8, 2009 | 01:30 PM
Scout's Avatar
Scout
I get about 15 - 20,000 out of mine, and do them myself. Last week I paid just over $200 Canadian for 3 sets of pads at the dealer. You need a small head 1/4" 12 point socket, and a 10mm 12 point. On the fronts, loosen pad pins, then remove the caliper pins and remove complete unit, then finish pulling pad pins tho get pads to drop out. On the rears, loosen pad pins only. Don't remove caliper pins. Make sure you push rear pad away from disk with a paint scraper, or you'll never get the new pad in. When the pads are seperated from the disk, finish pulling pins and have the pads drop. You'll see the pads only go back in one way, re-install and make sure you pump the brakes a few times before you go out riding, or you'll have no brakes.
Hope that helps. If not, a manual is a great investment.
Joe
Old Jul 8, 2009 | 02:44 PM
paguy's Avatar
paguy
Thanks guys. I'm close to it. There are some indy guys nearby, Death Row Cycles. May give them the business.
cubalz
Apr 4, 2014 08:21 PM
grumpy56
Oct 22, 2010 07:17 PM
Uncle Scrooge
Wheels/Tires
Aug 29, 2009 04:33 PM
ozzy07840
May 23, 2008 01:04 AM
Beavis
May 23, 2006 01:04 AM
