Brake Pads?
Old May 22, 2006 | 11:21 PM
Beavis's Avatar
Beavis
Default Brake Pads?
I'm ready to replace the rear brake pads on my 2001 Ultra and have searched the "how to" section with no luck. Do I need to remove the rear wheel, or can it be left on? Do I need any special tools, etc. Any helpful hints would be appreciated.
THANKS
Old May 23, 2006 | 01:04 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Brake Pads?
If you are patient, you can leave the rear axle in place......
Get a strong putty knife, and seperate the pads (1 at a time) from the rotor...
Get them as far into the caliper as possible.....
You need a 1/4" 12 point socket to remove the two little bolt pins holding the pads in place....
Remove the pins and hold the pads in place... Let the inside pad slide down first....
Pay attention to the orientation.....
Remove the outer pad....
Inspect the pins for wallowing, gouging, etc.....
If they are not perfectly round, replace them.....
Reinstall the pads, outer first.....
Install the pins partway to hold the pad in place....
Install the inner pad, while pushing up into the caliper to help the pins travel freely.....
Bottom out the pins, and tighten them up....
Reset your pads by pressing on the brake pedal a few times....
Done.....
Lastly, Invest in a service manual..... as well as an electrical diagnostics Manual... They will pay for them selves the first time you use them.....
Shovelhead Bob
Double.. Sorry..
Kbore
Oct 23, 2012 04:49 PM
grizzwold
EVO
Sep 4, 2011 08:08 AM
paguy
Jul 8, 2009 02:44 PM
ozzy07840
May 23, 2008 01:04 AM
Hdbiker1450
Oct 13, 2006 08:55 PM
