Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Cutting down a windshield???
Old Nov 9, 2007 | 10:03 PM
itileman's Avatar
itileman
Default Cutting down a windshield???
Have the saw, sandpaperand tape ready to go. Question is, what's the best shape to use? I'm taking off about 2" off the top of a 19" HD standard quick detach shield. Best to cut straight across the top or contour & shape to the original structure? Any help would be greatly appreciated. I've been reading the posts as to how it's done, just wondering what's the best cut to make.
Old Nov 10, 2007 | 07:33 AM
Road_Clam's Avatar
Road_Clam
Default RE: Cutting down a windshield???
ORIGINAL: itileman
I basically created a template of the original contour. The problem is as you remove height, you encounter added width. To overcome this I simply added a more gradual radius at the corners to compensate for the added width. I removed about 4" off my "King Size" WS. I like it much better, and it is still functional, and looks way better. I used an electric palm sander to remove the rough cut marks. I had to do a TON of sanding to get a clean line across the top.
Old Nov 10, 2007 | 02:44 PM
face's Avatar
face
Stage III
i cut the bottom edge off my ultra's windshield this maintains the top edge, just make acardboard stencil of the factory bottom edge which is hidden behind the fairing also use alot off masking tape on the shield so as to stop any scratchesm from appearing
Old Nov 10, 2007 | 03:54 PM
itileman's Avatar
itileman
Thanks for the info. I'm a contractor, so I have no shortage of sanders. Will probably have to go the contour route - cutting off the bottom won't work with the quick detach, I'd have to move all the framing.
My belt sander does a good job of shaping, router might work too. Will post results when it's done (if I still have some fingers left to type with).
utz
Oct 1, 2009 02:20 PM
mpmillion
Sep 23, 2009 04:18 PM
siramazing
Oct 23, 2006 12:01 AM
chunks
Jul 11, 2005 10:27 AM
skyking
17
Mar 10, 2005 02:21 PM
