Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Most comfortable 04' 1200c shock wanted- advice needed
Old Nov 24, 2007 | 04:37 PM
Kozak's Avatar
Kozak
Default Most comfortable 04' 1200c shock wanted- advice needed
I have seen reference to using a 13' or 12' air shock from a rk or ?? other big Hd
How is that done? They seem to be ugly black shocks but sooo much of he bike is chrome I could tolerate some ugly, I would rather function over form for performance comfort. height is no problem, if it raises the bike so be it, more cornering clearance unless it makes the front end push, then that would be bad.
new to the forum and love it already, thx
Old Jan 17, 2008 | 09:42 AM
rodhotter's Avatar
rodhotter
Default RE: Most comfortable 04' 1200c shock wanted- advice needed
you should get a longer shock unless low ride height is necessary,a longer shock will use a softer spring, my 12.5in prog model#4184807C uses a dual rate75/120 spring, fully progressive springs used on ohlins 36E for sportys give a better ride but cost more, quality is usually not cheap, lighter custom springs also available but you must open your wallet wider
gunslingersnation
Mar 23, 2019 10:48 AM
trnewman
Mar 17, 2015 09:10 PM
see22ds
Jul 9, 2013 02:58 PM
5speedblu
Jan 4, 2009 11:10 PM
drumer66
Feb 26, 2008 09:12 AM
