Just installed progressive 944s and have the pre-load set to the middle adjustment. I was thinking when the wife wants to ride I need to essentially extend the shocks which would decrease the pre-load. However, the installation instructions state that if excessive bottoming occurs you need to increase your spring pre-load, which shortens the shocks?? That does not make sense to me.
Am I thinking backwards on this???
Yes, don't think length. Think tension. Pre-load puts more tension (hence the load that is pre) on them, making them stiffer (sort of).
Sort of. The preload doesn't shorten or lengthen the shock. It's an adjustment of the initial load on the spring...the preload.
Simplistically, less preload gives a softer ride because it allows you to use a softer portion of the spring wind, but it won't handle heavier weight as well as more preload will which takes you into using the beefier part of the spring wind. That's actually where the term "progressive" comes from...the springs get progressively stiffer as you add more load.
Less preload is sort of like running less air in your tires...while more preload is like running more air in your tires. Yes, there's way more to it than that...but increase the preload when your wife wants to ride with you. I used Progressive 7610Ps on my race bikes way back in the day...great shocks...good choice.
Less preload is sort of like running less air in your tires...while more preload is like running more air in your tires. .
That's not really an accurate analogy. Putting more air in your tires (or shocks if you have them) actually makes them stiffer. Putting more preload on a spring does not make it stiffer. Spring rate is a function of coil diameter, wire diameter, and number of coils.... nothing else. If you preload a spring, you reduce it's travel, that's all. For example...
Say a spring has a 100 pound per inch spring rate and is 10 inches long. When installed it's preloaded 3 inches. It now has to see 300 pounds before it will start to compress. Take an identical spring and preload it 5 inches. It now needs to see 500 pounds before it will start to compress. Assuming both springs will go coilbound at 8 inches compression, they will BOTH be exerting 800 pounds of force. The only difference is that the 5" preloaded spring will not move under 300-400 pounds load and the 3" preloaded one will. The 3" spring will give a softer ride over small bumps because the 5" spring is like a rigid frame at that point.
The 5" preloaded spring will not bottom less under equal load.
Sorry, but this just is not true. Think about it.... how is compressing the spring with preload adjustment any different than compressing it with a passenger? It isn't.
The preload will just make the ride less "bouncy" with a heavier load as it will travel less.
It's like Bikerscum said, the spring does not limit travel since it will compress the same amount regardless of preload, unless you preload more than your load. Spring preload is adjusted so that the bike sags to the midpoint of shock travel under the intended load, giving you maximum suspension travel as you ride.
