Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
2003 Fork Oil Change Blues
Old Feb 14, 2008 | 08:29 PM
cocoaroadking's Avatar
cocoaroadking
2nd Gear
Default 2003 Fork Oil Change Blues
I recently drained the fork oil out of both shocks and refilled with harley brand type E fluid, the forks were removed during this procedure and filled them to within 4.21 inches from the top of the fork. I then very gently compressed the shocks about ten times each to get any air out. The forks were reinstalled on the bike and test road. The shocks feel like there is no shock at all, have i done something wrong, i read that there is a difference between regular shocks and ones with the cartidge inside. any advice would be greatly appreciated.
Old Feb 14, 2008 | 08:51 PM
HGM's Avatar
HGM
Default RE: 2003 Fork Oil Change Blues
Does your manual say to fill to a certain level?? Mine says to add 10.2oz if dry and 9.2oz wet. Period..
Old Feb 15, 2008 | 04:53 PM
cocoaroadking
2nd Gear
Yes, the manual says fill till 4.21 inches from top of fork.
Old Feb 15, 2008 | 06:07 PM
03dragonRK's Avatar
03dragonRK
Frist - Road Kings did not come with the cartridge in the left leg so unless it was added you have the conventional type. I think you over filled your forks. The 03 service manual calls out pouring 11.1 ounces of type E and then adust to 5.24 inchs from the top of the fork tube "With The Fork Comprressed" If did not open theforks up, butadded the oil through the fork tube plugthe springs would keep the forks extended. I would drain the forks again and then add only 10 ounces to each side as one of my HD instructions states 10.9 ozs per side and you will still have some oil left in the forks.
Old Feb 15, 2008 | 07:23 PM
cocoaroadking
2nd Gear
I will try that,I tried the 4.21 inches from the top of the tube and ended using almost 24 oz.s of fluid to get up to 4.21 inches.
Old Feb 16, 2008 | 11:07 AM
lecomte38's Avatar
lecomte38
For the Road King - drain them on the bike thru the bottom drain screw in the forks. Add 11 ozs of screamin eagle fork oil thru the top caps. go riding and enjoy.
Old Feb 16, 2008 | 11:11 AM
Classic Beast's Avatar
Classic Beast
Waaay too much oil. I use belray 30wt fork oil it's magic.
Old Feb 24, 2008 | 06:31 PM
cocoaroadking
2nd Gear
I drained the oil out and put the measured 10.9 ozs, rides great, i think i blew a fork seal though while test driving the bike with the forks overfilled. Getting a little drip from the left fork cover.
drooq
Apr 7, 2013 05:04 PM
keith t
Jun 7, 2012 02:07 PM
cbo111
Mar 17, 2012 10:05 PM
harley_jeff
Jul 25, 2010 10:52 PM
hennyhog1
Oil Archive (no new posts)
Apr 11, 2007 09:23 AM
