Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Help,wobble
Old Jan 24, 2009 | 06:32 PM
jeep10's Avatar
jeep10
Stage I
Default Help,wobble
09 HX when in a turn bike has a wobble faster the turn greater the wobble, talked to hd dealer they will look at next week anyone else had this problem?
Old Jan 30, 2009 | 12:47 AM
Kbore's Avatar
Kbore
Welcome to the forum. THis is always a hot topic on the forum. Just do a search on Harley wobble and I GUARANTEE you'll find more than you ever wanted to know.
Mosey over to the the main forum page and click on the new members area and introduce yourself too- and post a pic of your bike if you have one. Dont ask any questions there, just introduce yourself. After you do that, you will probably get a response or two to your question. Its kinda bad manners to just jump in start asking questions without even introducng yourself- just like it would be any where. Just asyin...
Welcome to the forum!!
Old Jan 30, 2009 | 06:24 AM
rjmac53's Avatar
rjmac53
Bagger Brace...end of story!!!
Old Jan 30, 2009 | 06:46 AM
rh8234's Avatar
rh8234
Check tire pressure - front and rear. Check tires for wear - especially cupping. If you have laced wheels, check all the spokes to make sure they are tight. Check both wheels to make sure the spin true. Check tire balance. If problem still exists, check alignment (you will need the service manual). Check the fall away (steering head) for proper adjustment. Just a side note, on my Dyna, I have learned that the steering head needed to be slightly tighter than the manual suggests to eliminate any minor wobble.
Old Jan 30, 2009 | 03:30 PM
hogbag07's Avatar
hogbag07
+1 above.
http://www.bikernet.com/avon/PageViewer.asp?PageID=212
Old Jan 31, 2009 | 07:10 PM
mp's Avatar
mp
Hmm. Thought the new frame was supposed to eliminate this. Maybe the bolts that hold the back half of the frame on need tightening.
Old Jan 31, 2009 | 10:53 PM
Lonewolf176's Avatar
Lonewolf176
+1 to check is alignment. I added stabilizer to my '07 and although bettter, when pushed it still would wobble. Just did alignment using tools (Georges Garage) and I had to adjust top stabilzer almost 1/8". When I get back running I hope will post if this helps.
95ci springer
2014-2024 Touring Models
25
Apr 3, 2017 05:05 PM
cycle crazy
Sep 4, 2013 01:54 PM
hooliken
Sep 6, 2008 09:21 AM
Jumpman
May 27, 2008 08:35 PM
hAkron
Aug 3, 2007 03:55 PM
