Front end wobble
Old Mar 31, 2017 | 08:05 AM
95ci springer's Avatar
95ci springer
Default Front end wobble
If I let go of, or very lightly hold the hand grips when I down shift or let go of the throttle, I get a bad back and forth movement of the handle bar that gets worse the longer I keep my hands off of it. Stops when I grab the bars again. Any ideas? 2015 FLHTK, 13k on it. I'm putting new tires on soon and will check the bearings but I'll take all the advice I can get. Thanks!
Old Mar 31, 2017 | 08:24 AM
jdunn01's Avatar
jdunn01
First things first, How many mile on the front tire and is it cupped.
Next the neck bearing is adjusted correctly. Section 1.20 of the Service manual
Check this tread: https://www.hdforums.com/forum/new-ru...-wobble-2.html
GaJayHawks post #16
It appears he found a solution to his wobble.
Many people have many different cause/solution but these seem to be the first things to check.
Old Mar 31, 2017 | 08:31 AM
TOFTS's Avatar
TOFTS
fall away check then adjust neck bering per manual
Old Mar 31, 2017 | 10:05 AM
95ci springer
13 k on the OE tires. 36 psi air. No cupping. I'll check the riser bolts. As for the fall away, I read it and didn't really understand it. I'll read it a few more times. Thanks!
Old Mar 31, 2017 | 10:39 AM
95ci springer
I should add that it's more like a death wobble. But only when the front end gets loaded up on deceleration.
Old Mar 31, 2017 | 11:03 AM
smitty901's Avatar
smitty901
You have one or more of the following
Neck bearing that needs adjustment, Has it ever been done?
Adjusting the neck bearing is not uncommon in first 20K.
Defective front tire, It happens from time to time
Bad front bearing , that is easy to check.
I would sure hope it don't need new tires at 13K. If they are at the wear point at 13K some serious issues are going on.
Old Mar 31, 2017 | 11:58 AM
Rustrtal's Avatar
Rustrtal
Mine does this when the neck is loose. Pain in the *** to get to it but after a couple times, it isn't too bad. I can get it done in about 30 minutes.
Old Mar 31, 2017 | 12:13 PM
95ci springer
I need a new rear tire since it has 3/32 left and I'm going to thin whitewalls so they are both being replaced. I'm assuming to check the wheel bearing, lift the bike and feel for slop on the wheel? Neck bearing?
Old Mar 31, 2017 | 12:29 PM
plongson's Avatar
plongson
I get a wobble letting off the bars at like 30mph, anything after that it's solid as a rock...where does yours wobble at?? The easy fix is to not let go...
Old Mar 31, 2017 | 12:34 PM
95ci springer
if I wind up first or second to the shift point and let go and not shift.
