Monkey Butt....whats your cure?
Old Oct 12, 2014 | 06:21 AM
baka1969's Avatar
baka1969
Riding compression shorts
HD Road Zeppelin (or Airhawk R) seat pad
Gold Bond Powder
Old Oct 12, 2014 | 06:59 AM
oldNbold's Avatar
oldNbold
The right underwear goes a long ways toward prevention of swamp ***. I read a good thread about the best choices for long rides. Ill see if I can find it. Cotton is not a good choice. I chose one from Underarmour. Seams are killers as well.
Old Oct 12, 2014 | 07:04 AM
OLDDEADEYE's Avatar
OLDDEADEYE
Originally Posted by Crazy Biker
This stuff works, I use it any time I'm going to be on the bike more than 100 miles a day.
davidwruth's Avatar
davidwruth
Gold Bond also makes a anti-friction stick looks like deodorant stick, they work well for me
Old Oct 12, 2014 | 07:15 AM
Notgrownup's Avatar
Notgrownup
Originally Posted by NuckaMan
Laid down 710 miles in 12 hours today....prepping myself for a Iron Butt Saddlesore 1000. Only time I was off the saddle was for 5-10 minute gas stops, other than that, I was moving.
First 4-5 hours, I was good. Latter part of the day, I was squirming pretty good in my seat cause my butt was getting sore. I should have taken more and longer breaks but I going for time and duration.
For you long-haulers....what's some of your Monkey Butt cure secrets? Certain type of underwear? Padded shorts? Certain jeans?
My bike is a RGU with Mean City Cycles Super Narrow cut, which I like alot.
Thanks.
Good seat, good underwear, either a air hawk or a circulator pad to keep pressure off to keep the capillaries flowing.
Old Oct 12, 2014 | 07:46 AM
PPBART's Avatar
PPBART
I've done a lot of 500-600 mile rides. My longest day so far is a bit over 700 miles in 14 hours, much of that was across Oklahoma in August (blister hot!). I've tried just about every option for long-day seat comfort: sheepskin, Air Hawk, HD Circulator Pad, gel pad, Bead-Rider. That last choice (with Under Armour underwear and Anti-Monkey Butt Powder) has worked best for me! True, it's old school, not that pretty, but it works -- and it was the cheapest solution of everything I tied. The key to reducing monkey-butt is air flow, and the beaded seat cover really facilitates that.
Old Oct 12, 2014 | 08:27 AM
Gliden's Avatar
Gliden
My longest 750 one day, jersey to NC. (Tenn)
My *** started to hurt when we got passed 500 miles.
Thank god for gas stops to shake it off.
After we arrived (about hour 13/14) I didn't want to ever drive any further in one day.
It was a blast but 750 or so is my limit.
Old Oct 12, 2014 | 09:31 AM
NuckaMan's Avatar
NuckaMan
Thanks guys for the input.
What I meant by Monkey Butt (I really don't know what it is also, just heard the term), was that my *** was getting pretty sore later part of the day.
After hearing about the suggestions of underwear, I think that would have helped. I was wearing some cotton's with seams on it, yeah, many hours sitting on them might have made my more sore than it should have.
I'm going to give myself another Iron Butt training run before going for the real deal and try some athletic style underwear like Underarmor.
Old Oct 12, 2014 | 09:49 AM
PanhandleChuck's Avatar
PanhandleChuck
The obvious answer is the right seat and gear. Duh, right?
LD riding shorts are a game changer. I switched to them a few years back.
http://ldcomfort.com/store/mens-dryline-shorts.html
I have two pair, you rotate them and wash them in a hotel sink, dry overnight.
Your gear needs to breathe. I wear mesh gear with only LD riding shorts underneath. Depending on your bike's wind protection, you can do this year round. I was in Maggie Valley last weekend, 32-36 degrees the first few hours in the morning. I had on BMW Airflow pants and jacket with LD riding shorts only underneath, no full length pants with seams. Of course, I had a Gerbing's Jacket and heated grips, but the lower fairing protection was good enough. I wear dry fit moisture wicking socks and shirts next to the skin, layer for cold weather and remove at stops.
The seat is always subjective. However, a firm seat is the answer. If your just uncomfortable with no hot spots, the LD riding shorts will help a lot. You need to get air movement in your gear and remove moisture. Try positioning yourself on one "cheek" at a time, slight angle left or right, to allow air flow. Colder weather would be ideal for these type rides, but not always possible. I use this gear in triple digit and freezing temperatures.
Old Oct 12, 2014 | 09:53 AM
Jonesee's Avatar
Jonesee
Compression shorts are a NECESSITY (no underwear, just compression shorts)
Sheeps wool or a folded thin towel over the seat as a minimum.
(if you can find an airline blanket, they are small and thin and work very well.
Some IBA riders use the beaded seat pads. I've never tried it so I can't say.
I run a folded airline blanket over sheeps wool and compression shorts. My body wears out before my ***.
If you are able to run 700 miles straight through, you are more than ready for your IBA ride. Grab some compression shorts, try them out then hit the road.
If you have any specific questions, send me a note if you want to ask in private.
Good luck. Ride safe.
