Monkey Butt....whats your cure?
Loose pants that allow the breeze to flow up your legs (or allow the breeze through) are a big, big plus). Shift occasionally to allow blood flow, and hydrate. A good seat.
You should be good.
You should be good.
Wear some form of Underarmor shorts or similar moisture wicking product and spend less than $100 bucks on Beadrider beads that you sit on.
Your results may vary. Past performance cannot predict future results.
For your tired butt, strange, but after a couple days of riding, your butt gets toughened up, seriously. The more you ride, the longer you can go, so build up some saddle time before your longer trips.
The ergonomically correct position is that of a sport bike. Feet underneath you and slightly leaned forward. Cruiser people can't understand how sport bikes can be comfortable, but I could ride my Honda CBR1000RR for longer distances than anyone I knew on a Goldwing.
I don't ride with my feet on the passenger pegs the whole time, that would look stupid. But, it's a fine stretch from time to time to lift yourself up off the seat and move around to get the blood flowing.
I have my mid-controls and my hi-way pegs. Works great. Keeping your feet in one position leads to cramping. Move your feet around a little bit every now and then.
I also found out that vinyl sucks swamp gas. Might last longer but so what?
I got a Danny Gray butt crack solo that doesn't look like much but I'll tell you what -- With the GEL foam they use, it makes the seating area firm.
You sit on it at first and go, "Too firm, I'll cramp up."
Nope. My buddies are always wanting to pull over while I'm ready to keep going.
It could also be the seating position of your bike. Some people are more comfortable on an FL frame and others (like me) are more comfortable on an FX frame.
The FL frame sits like you're on the toilet.... Or something. The Dyna lays you back more. But that's just me. Everybody's different.
Maybe it's the seats they put on the FLs?
Start with one thing first -- Foot positions.
If that works, great. If not, look at a different seat.
If none of it works, buy a trailer. Your friends who break down on the road will appreciate it
Monkey butt has a few more meanings doesn't need to be discussed.
12" mini-apes you get from HD here.
1 1/4" diameter, 8.25" rise w/ 1" risers.
