the engine stalled.why?
Old Apr 15, 2007 | 08:10 PM
Dancemax's Avatar
Dancemax
Default the engine stalled.why?
I have a 03 Heritage Softail, 7500 miles. was running perfectly. I went for a ride today with1/3 tank of gas. I filled it "UP to TOP" 5 days ago. As I came to a stop, the engine stalled. I got it started but it sounded a little hesitant so I kept it going with some throttle and headed back without much stopping. Now it seems ok. I let it run in garage and also started a few times without any problems. I am concerned.
water in gas?, time to change spark plugs?, Stage I upgrade Mapping problems (I dont what that means)
or what. What should I do...take it now to the dealer or wait and ride again later.No warranty
Old Apr 15, 2007 | 08:28 PM
Dick Johnson's Avatar
Dick Johnson
Default RE: the engine stalled.why?
How many miles did it take you to burn all that gasoline? Take your plugs out and inspect them, if they're black and sooty your injectors may be hanging,and if you are running that rich you need to see your dealer. If they are tan then your mixture is good and you may have a problem with bad gas or water in your gas.. If thats the case then drain your tank and start over.
Dick
Old Apr 15, 2007 | 08:31 PM
pgd357's Avatar
pgd357
6th Gear
I had a 79 triumph that did that on me. The Gas cap vapor locked on me and stalled the bike every couple of blocks. I cleaned the vent hole and it worked fine.
Old Apr 15, 2007 | 08:34 PM
pgd357's Avatar
pgd357
6th Gear
I forgot to add..... everytime the bike stalled it started right up. If the bike stalls again on you. Loosen the cap and see if it runs with stalling.
Old Apr 15, 2007 | 10:06 PM
Crushertx3's Avatar
Crushertx3
sounds like you have a computer problem with your bike we just went throught it on a Road Glide
Old Apr 15, 2007 | 10:23 PM
High Gear's Avatar
High Gear
My bike acted that way when the module was going out .
Old Apr 15, 2007 | 10:58 PM
Dancemax's Avatar
Dancemax
Can a dying battery do that. When I put on battery tender it is taking for ever to charge it. It never used to be like that. Tell me this, if you have a engine runningand then you disconnect the battery, will the engine stall?
Old Apr 16, 2007 | 01:32 AM
Crushertx3's Avatar
Crushertx3
yes if your charging system is not working properly
heavychevy7485
Carburetor Related
Jul 4, 2011 07:50 PM
petemac
Oct 25, 2010 05:38 PM
rocksandgiz
Exhaust System Topics
Dec 28, 2007 02:00 AM
mslater741
Aug 21, 2007 06:14 PM
brycharz
Aug 8, 2007 02:55 AM
