Mixing tire types ?
Old Jan 3, 2015 | 11:31 AM
GaryInDelta's Avatar
GaryInDelta
Default Mixing tire types ?
Back in the day, I know you were not supposed to mix bias ply tires with radials on cars or trucks. What about bikes? Sometimes you find a great price on a tire only to find that it's a radial (or bias ply) and the next bargain tire is for the different ply type.
How do different ply types on a bike affect handling, (i.e. radial on the back, bias on the front)? Also, which wears, corners, stops better?
I've never seen this discussed here or anywhere.
Gary In Delta
Old Jan 3, 2015 | 12:17 PM
wilsoda's Avatar
wilsoda
I had a radial back/bias front Avon Cobras on my 2012 Fat Bob. This was the configuration recommended by Avon and rode great. When the indy shop first suggested it I did some searching online and found that the mix was a common setup.
Old Jan 3, 2015 | 02:15 PM
bdtaylor1979's Avatar
bdtaylor1979
I have done that before and never noticed any differences in handling or anything like that.
Old Jan 3, 2015 | 02:34 PM
O-Town D's Avatar
O-Town D
Late last year I swapped out the OEM wheels for some 18-inchers which were mounted with a Metz bias on the front and a Metz radial on the rear. My impressions have been the bike handles/rides as well as, if not slightly better than, the OEM setup, at least in the dry - have not tested in the wet as I try to avoid riding in inclement weather. I believe HD and a couple of other mfrs in the recent past have installed bias frt, radial rr tires as standard on a couple of models, so it doesn't appear to be as much of a 'no-no' as it was years ago when radials first came out on the market. Good luck with your choice.
Old Jan 4, 2015 | 09:44 PM
oct1949's Avatar
oct1949
even some new bikes come with Bias on the Front and Radial on the Rear.. the sons Deuce or NT came new that way from the factory..
Old Jan 4, 2015 | 10:24 PM
cardboard's Avatar
cardboard
Done it for years.
Old Jan 5, 2015 | 06:28 AM
'05Train's Avatar
'05Train
No issue.
Old Jan 5, 2015 | 09:10 AM
garyl's Avatar
garyl
Same here, no issues with mixing.
REGGAEX
2014-2024 Touring Models
Sep 3, 2017 08:05 AM
cowpoke
Wheels/Tires
Aug 5, 2013 06:54 PM
IronAss
Aug 16, 2010 12:13 PM
tmultra
Mar 25, 2010 03:57 PM
strtarrow
Dec 23, 2009 06:14 AM
