Tire pressures...
Old Jan 21, 2015 | 08:45 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Originally Posted by bdtaylor1979
The cold weather will make the tire pressure drop a few degrees.
Yep and every first cold day, both cars "low tire" lights are always on.
Old Jan 21, 2015 | 08:50 PM
heybaylor's Avatar
heybaylor
I rode mine today.
Old Jan 21, 2015 | 08:55 PM
Mi3ninos's Avatar
Mi3ninos
OP - take your hook out of the water. Your over the daily limit.
JMC22's Avatar
JMC22
Originally Posted by Bone Doc
The rule I use is:
For every 10*F change in temperature, the tire will change 1 psi
If the temperature decreases 10* --> the tire will lose 1 psi
If the temperature increases 10* --> the tire will gain 1 psi
So does this apply if one fills their tires with nitrogen instead of air?
Old Jan 21, 2015 | 08:56 PM
Harleycruiser's Avatar
Harleycruiser
Warm air expands, tires expand some but not as much.
Old Jan 21, 2015 | 09:02 PM
JustOneDean's Avatar
JustOneDean
Yes. The numbers would be different, but not by much - regular air is about 78 percent nitrogen.
Old Jan 21, 2015 | 09:29 PM
dandrumheller's Avatar
dandrumheller
I think if you inflate both tires to the proper pressure in the garage, they will lose at least a couple pounds when you roll the bike out the tunnel. Be careful though, even if you air them back up, the front is likely to be around 28, and the rear may still be at 0.
Old Jan 21, 2015 | 09:44 PM
Bone Doc's Avatar
Bone Doc
^^^ This
For the most part, yes. Nitrogen, like any gas, still follows the same gas laws including temperature is proportional to pressure. But, Nitrogen usually shows less pressure fluctuations with temperature changes than air. This is because pure Nitrogen is dry. Air is mostly N2, then O2, then CO2 and then traces of other gases. The presence of water vapor in the air is a major factor that increases the susceptibility of air to the temperature-pressure changes.
Old Jan 21, 2015 | 09:56 PM
Deucedog's Avatar
Deucedog
Originally Posted by seniorsuperglideE8
If I inflate my tires to the proper pressures in a warm garage, say around 70 degrees, then park the bike outside where the temperature is 45 degrees and my tire pressure drops a couple degrees. Did somebody "deflate" my tires or did the ambient temperature cause this pressure drop? I hope the metaphor wasn't too difficult.
Yes, colder temps will cause tire pressure to drop a few pounds. Every winter my cars tire pressure monitoring system light comes on.
I add about 4 lbs of pressure, the system is happy, and I'm good until warmer weather.
Assuming that you're going to be riding in cold temperatures for a few more months why not just park the bike outside. Let the tire temp stabilize, check/adjust your tire pressure, and forget about it. What happens inside the 70* garage is not important, it's what happens when your bike is outside that's important
Old Jan 21, 2015 | 09:58 PM
joe.1955's Avatar
joe.1955
It depends on whether they are New England or Indianapolis tires.
