Tire pressures...
Old Jan 23, 2015 | 08:05 PM
  #41
DannyZ71's Avatar
DannyZ71
Originally Posted by Bone Doc
You should fill the tire to the maximum recommended pressure only if you will be carrying the maximum recommended weight on the bike. Which means, in general, riding two up with some gear. If I do not have near the MAX recommended weight (riding solo), I keep each tire at 2-3 psi less than the recommended MAX pressure as specified by the tire manufacturer.
Overfilling the tire unnecessarily only reduces the contact patch (traction) and cause unnecessary wear in the center of the tread.
Here is a common misconception about tire inflation. A tire is not made (generally) specifically for a single vehicle. They are made to fit a multitude of different vehicles, all different in weight, etc. The "max tire pressure" should NEVER be used solely. A tire with a max tire pressure of 60 psi can be dangerous if inflated to such levels but on a vehicle that only needs 30-35 psi to operate safely. A 31x10.50R15 tire on a midsize pick-up should not be inflated to the same pressures required for a 3/4 ton truck even though both can use the same size tire. Likewise, the same size tire on a Dyna should not be inflated to the same pressures as it would be on an Ultra.
Always follow the VEHICLE manufacturer's recommendation. It is based on vehicle weight, suspension, etc.,.
Old Jan 23, 2015 | 10:48 PM
  #42
TI06's Avatar
TI06
Originally Posted by seniorsuperglideE8
If I inflate my tires to the proper pressures in a warm garage, say around 70 degrees, then park the bike outside where the temperature is 45 degrees and my tire pressure drops a couple degrees. Did somebody "deflate" my tires or did the ambient temperature cause this pressure drop? I hope the metaphor wasn't too difficult.
Not a lot of football fans around here eh
Old Jan 24, 2015 | 04:17 AM
  #43
Phil from Barrington's Avatar
All you need to know about temperature and pressure can be found in just about every US newspaper in the country over the last week. And more will come for sure.
Old Jan 24, 2015 | 06:26 PM
  #44
rdam's Avatar
rdam
It was.
Old Jan 24, 2015 | 06:37 PM
  #45
dandrumheller's Avatar
dandrumheller
Originally Posted by rdam
It was.
For some. Not so much for others...
Old Jan 24, 2015 | 08:03 PM
  #46
Bone Doc's Avatar
Bone Doc
If this is the case then, whose recommendation do you use if you change the tires to something other than what came with the bike? You can no longer use the owners manual (aka vehicle manufacturer's recommendation) because it is a different tire.
I highly doubt each vehicle manufacturer has a database of what the recommended tire pressure should be for every tire on every vehicle. The only other guidance you have then is to use the tire manufacturer's recommended pressure.
Old Jan 25, 2015 | 02:21 PM
  #47
DannyZ71's Avatar
DannyZ71
I've not seen any data base. But, if you look at the owners manual, they talk about tire size, not manufacturer. Same with four wheelers. Look inside the driver's door and you will find that vehicle's recommended tire size, and inflation recommendation. Those recommendations are for that particular vehicle, it's suspension, it's gross vehicle weight, and the vehicle's purpose. It's common sense. If you change tire sizes to something not recommended by the vehicle maker, you are usually on your own to find out what works best for the vehicle. Ride quality, etc. Over-inflated tires are especially dangerous and detrimental to the vehicle's handling.
Another example: When switching from Dunlop to Michelin Commander II tires for my last bike, I stayed with the vehicle maker's recommended sizes. However, I found that the tires did better when I upped the PSI a few pounds. Ran 40 in front and 42 in the rear vs. the recommended 37 and 40. But, that was for tread wear purposes and ride quality. But, it was no where close to the max psi printed on the tires. So even the vehicle maker's recommendations can be played with a little. "Little" being the keyword here.
18Slim
2018+ Softail Models
Jul 27, 2019 11:31 AM
Jack Dawkins
2014-2024 Touring Models
Jan 19, 2018 03:10 PM
Sprinter7x
May 10, 2014 09:40 PM
tuckertaft
Aug 16, 2010 03:48 PM
bnsoftailrider
Aug 24, 2006 12:41 PM
