What if his reply is extra virgin olive oil? Read your manual, it will tell you which oil to use.
If that is the case, then you have to ask if it is Italian or Spanish and what weight.
I wouldn't bother calling the PO myself. At lest not about what brand/type oil. Not that important, IMHO. As someone previously noted, when I bought my HD from the dealer (used) they had done the 5000 service on it before they put it on the floor. I read the manual and decided to use one of the recommended oils when I changed it. No problems.
But, not all. Not sure if it has been stated, but what if the previous owner is no longer with us? Might cause some grief to whomever answers the phone?
Myself, I always change oil and other fluids/filters on newly purchased motors, so that I can be sure of what is in there. To me, that is the best policy...
If you didn't buy it from him, don't call and ask questions.
I traded a real slick, low mile pickup to a dealer years ago. About a week later I start getting calls in the evening asking me about the mileage on the truck, and was the engine original, etc. All the callers said the dealership gave them my name and number.
I drove to the dealer and expressed my displeasure with what they had done. I also explained that if I was going to help sell that truck, I would need some of the $ the sales force would earn on it.
I don't see a problem with calling once and leaving a message if there's no answer, but if you never hear back, I'd leave it there.
At everyone saying it doesn't matter what oil the PO used: It's helpful to know, depending on how many miles the bike has. The main question is conventional vs. synthetic, as over time the gaskets and seals become conditioned to the type of oil they're regularly exposed to. It's not a huge issue, but switching to synthetic oil after running dino for 70,000 miles can cause minor leaks. The flip-side is, switching from synthetic to dino after the same amount of miles may help alleviate some minor leaks that have cropped up over time.
Thank you for this response.
Man I really didn't expect the backlash. I guess I should have been more specific. I prefer to run full synthetic in everything I own. Several people, some who are Harley mechs, have told me to find out because if the previous 1 owner ran only dino oil switching to synth at 50K can start leaks.
I called the shop. Turns out previous owner was an Amsoil rep and that is all that has been run in it.
Man some of us have some serious PMS ( Parked Motorcycle Syndrome ).
...because if the previous 1 owner ran only dino oil switching to synth at 50K can start leaks.
An article I read a few years ago, stated this is no longer true. During the time synthetics were first introduced, there had been some problems, but since then the newer synthetics have been chemically altered so as to not cause harm to the older materials used in the making of seals. Newer seals have also been changed to accommodate less problematic usage of synthetics.
The only drawback these days with switching from dyno to syn oils, according to the same article, might be synthetic oil cleaning out any sludge that had accumulated around an older seal which may have hardened and possibly even have cracks in them that the sludge kept from leaking.
I think that's mostly true, but I believe the issue when switching to synthetics is that they have a finer, uniform molecular structure, so they simply fit where the dino oil won't if the gasket is "used" to dino. I don't doubt that the seals have been refined over time to adapt to this, but I don't know to what extent. I'm not a chemist or an engineer, so I could be way off here.
It's not a question of ethics, but of courtesy. That really comes down to a personal choice, balancing your perceived need against your perception of potential discourtesy. If you call, you just lead off with asking if he minds talking to you about the bike. If so, "Sorry to bother you, goodbye".
Any ethics that come into it are for the dealer and the shop, and whether they give you information about someone else's business.
