I read that you should warm up the engine before changing the Oil, Trans and gear fluid (I agree). My bike has been in winter storage since November in a heated shop. My question is, do I need to take it for a short ride to warm it up or can I just lift the rear wheel off the ground, start it and let it run a while to accomplish the same thing? Thanks for the input.
Why wouldn't you want to take it for a ride? If you are unable to, for whatever reason, then just leave it alone until you can ride it. It's been sitting all winter, it really needs to be taken for a good ride (15-20 mi.) to burn off any and all condensation that has built up in there over the last couple of months.
In my opinion, if you cant take it for a ride, you could just start it up and let it run for 5 minutes to get the engine hot and change all 3 fluids. That will allow the oil in the upper parts of the engine to flow out better. The trans and primary don't really have passages for oil to flow through like the engine does so I don't think taking the bike for a ride would make any difference in changing those fluids, except they would drain faster because they are warmed up.
Running the engine before an oil change is particularly important on a Sportster - the oil tank is above the crankcase and the risk is that some oil will backdrain into the sump when sitting. Then you drain the tank and miss the oil in the sump. There is NO sump drain on a Sportster. You then put in the required amount, check the dipstick and all looks good...
until...
...you fire it up and go for a ride. A mile down the road your dipstick blows out like a roman candle and you get oil all over your jeans and polo shirt.
Your oil pump just scavanged the extra quart out of the sump and essentially tried to stuff 10 lbs. of **** in a 5 lb. bag
This is not so much a problem on the twin cams, they have a sump drain.
5 minutes running while sitting will not get temps up any where near where they need to be.....might as well do cold change. A 15 mile ride at good speed is the ticket.
