pulled head off - change gasket?
Old Mar 19, 2015 | 05:57 AM
oldairboater's Avatar
oldairboater
Don't half *** it. If you do you will pay for it later.
Old Mar 19, 2015 | 05:42 PM
heybaylor's Avatar
heybaylor
Originally Posted by FNGonaRK
If you pull the cylinders, you might as well bore and sleeve them and replace the pistons. If you do that, you should change the rod length as well.
yes , and send the cam out for a grind , don't forget the paint shop
Old Mar 19, 2015 | 06:00 PM
senna's Avatar
senna
Just build a 107 and be done with it, no wait a 117 or a 120 something. Does it ever stop?
I believe if you pay attention to keeping the cylinder down against the case that you will be fine on a low mileage O ring.
Old Mar 19, 2015 | 06:41 PM
Harleycruiser's Avatar
Harleycruiser
Have you actually done this?
Op the o ring is less of a gamble than disturbing the rings leave it.
Old Mar 19, 2015 | 11:21 PM
bobx67's Avatar
bobx67
i left the O ring alone. we'll see what happens. thanks everyone.
Old Mar 19, 2015 | 11:52 PM
lh4x4's Avatar
lh4x4
Pulling the heads is easy. So it is no risk or gamble to just put them back on. Should the lower O ring leak it is not much more effort to pull the heads then do the seal.
It seems to be worth just putting the heads back on to proper torque.
A minor leak is not going to grenade the engine. Nor is it much addition work to go ahead and replace the gasket. The only duplicate rework is removing the head.
I do all my own services and have yet to even replace the drain plug O ring. My 10 Ultra had six services on it before I traded. I did check them for cuts and tears. I have a half dozen new ones on hand if I ever need one. I have reused gaskets most of my life without fail so far. Took the final drive on the Ural apart three times. No leaks.
Rickr01
Milwaukee Eight (M8)
May 2, 2018 10:50 AM
drhooligan
Engine Mechanical Topics
Nov 11, 2016 05:47 AM
natural gasser
Exhaust System Topics
Feb 17, 2013 12:41 PM
HarleyReece
EVO
22
Jun 26, 2012 05:09 AM
JimmieJack
Feb 7, 2011 08:24 PM
