Base Gasket
Old May 2, 2018 | 06:11 AM
Rickr01's Avatar
Rickr01
Default Base Gasket
Can someone please tell me if the base gaskets need to be changed when a head is pulled and replaced on the new M-8's? Thanks
Old May 2, 2018 | 08:17 AM
Keithhu's Avatar
Keithhu
They arent gaskets, they're o-rings. I would imagine you could re-use depending on their condition, but why?
Old May 2, 2018 | 08:20 AM
lp's Avatar
lp
If you're just doing head work and not removing the cylinders I don't know why you'd change the Orings out. Is that what everyone does?
Old May 2, 2018 | 08:27 AM
Rickr01's Avatar
Rickr01
The M-8 went back to base gaskets. They are not O-rings in the new M-8 motor. Coated base gaskets.
Old May 2, 2018 | 08:29 AM
Keithhu's Avatar
Keithhu
I stand corrected then, thanks.
Rickr01's Avatar
Rickr01
Because you are taking the torque off the gaskets by removing the heads in all pre M-8 motors. I'm not sure if its the same with the M-8?
Old May 2, 2018 | 08:56 AM
Rickr01's Avatar
Rickr01
Not sure it was the best move? Remains to be seen?
Old May 2, 2018 | 09:18 AM
Keithhu's Avatar
Keithhu
Uhr....not sure what you mean, but ok.
Old May 2, 2018 | 10:34 AM
Rickr01's Avatar
Rickr01
Back to base gaskets over the recessed o-ring?
Old May 2, 2018 | 10:50 AM
VDeuce's Avatar
VDeuce
I have done them without changing the base gaskets. No leaks, but you throw the dice and take your chances. Be sure the cylinders don't move when you pull the heads and if you will be rotating the engine, use some cut up pieces of pvc around the head bolts and secure them so the cylinders don't move. Good luck!
RLH3175
EVO
13
Jul 9, 2016 10:08 AM
hdHuck
EVO
Aug 16, 2014 06:20 AM
borncountry
Jun 1, 2012 09:26 PM
Sheets1958
Sep 2, 2011 05:54 PM
rivercityslim
EVO
Nov 16, 2009 02:50 PM
