Leaking Gas from Quick Disconnect
Old Apr 29, 2015 | 09:28 PM
Panama FATBOB's Avatar
Panama FATBOB
Default Leaking Gas from Quick Disconnect
2012 Fat Bob. I had not been able to ride for about a month and when I started the engine gas leaked from the quick disconnect. As I understand, the "usual" culprit is the 1st O-Ring Seal found in the female connector that is attached to the gas tank. I tried to pick the o-ring without luck. I see that the female quick disconnect looks threaded into the gas tank, but I am not sure. It does have a hex head. I tried to pick the seal with the tank half full but every time I tried to pick the seal, gas came down.
Assuming I remove most of the gas, is the quick disconnect female difficult to remove ? Of course it can be unscrewed, but I wonder if it is connected to something else inside the gas tank and if I removed it I would then get into more trouble. I was planning on removing the quick disconnect female connector and work the seal out with a bit more space on my work table.
Appreciate comments, Thanks....Al
Old Apr 29, 2015 | 09:32 PM
Smokey Stover's Avatar
Smokey Stover
There's a good video on Youtube, You'll need a special tool, or get it to a shop.
Bird-man's Avatar
Bird-man
Had the same problem with an '08 Heritage. I took it to an Indy Mechanic. It was a real pain to fix. He had gas all over himself, the floor, the bike. I had to leave for a bit, it took him about 3 hours...and he said it was not fun! He had to replace the entire quick connect fitting. Good luck.
Old Apr 29, 2015 | 09:37 PM
formula223's Avatar
formula223
If your 2012 is the same as my 09 it can be done without the special tool. You need to go in through the top of the tank to replace it. Be careful not to damage anything and cover the tank with a towel. Wasn't too difficult of a job.
Old Apr 30, 2015 | 11:27 AM
Panama FATBOB
Default Thanks...Just bought the "Tool"
Decided to go after the special Fuel Tool. The only thing is that I need to wait until it gets to Panama. 2 to 3 weeks.
JonW
Jul 30, 2012 02:41 PM
paullavery
Dec 2, 2010 11:19 PM
jluvs2ride
Mar 29, 2010 02:41 PM
1075
Jan 4, 2009 10:53 AM
tony2nuts
Exhaust System Topics
Jun 15, 2005 12:49 AM
