Gas tank internals
Can anyone give me a link that I can download for instructions for fitting these so I make sure I have done it right & also is it advisable to replace the screws and rubber gasket for the top of the tank or can I use the original ones ?
Thanks in advance.
Paul.
https://www.hdforums.com/forum/dyna-...tank-guts.html
Hope to be working on mine soon, too ....
R/
'Chop
I had actually taken my tank apart once before when I had some clear coating on the stock tank done, and another time when I swapped to the custom stuff...so they have been re-used twice.
Have you got alot of snow where you are ? Find it amazing that everything grinds to a halt here with a bit of snow, but then again its not something we are really use too !!!
http://cgi.ebay.com/ebaymotors/Harle...item2a0c4d4a85
Adjusting for Tank Lift:
I put a half gallon in then I bent the float rod right by the sending unit (the rod has a "V" shape angle there). I opened that angle up a little, reinstalled sending unit and with the bike upright and my weight on it, I recycled the power and run switch and waited for the gauge to settle (theres a delay in the circuit). I had to do this several times to get it right where I wanted it.
Now when the low fuel light comes on I have a half gallon left. Also when my gauge is now reading a half tank and I top it off I usually pump in about 2.2 to 2.3 gallons (4.7 gallon tank)
While your in there you might as well check your internal fuel lines, info here:
https://www.hdforums.com/forum/dyna-...fuel-line.html
Fuel Lines:
I think the fix would be to use Gates SAE 30R10 Submersible Fuel Line, using a shorter length so that it doesn't hit the tank walls, and / or putting tie wraps on those contact points. Harley only sells the one line from the tank quick disconnect to the regulator/filter, the other line requires you to buy the fuel pump.
fuel line tank output to pump item #19 P/N 62194-04
Retail: $55.92
Chicago HD: $44.74
Zanotti's: 36.35
fuel pump assembly item # 7 P/N 61016-04B
Retail: $160.00
Chicago HD: $128.00
Zanotti's: 105.92
fuel pump assembly with regulator item #26 75218-04B
Retail: $250.00
Chicago HD: $200.00
Zanotti's: ?
Original Part Numbers (Parts that originally came on your bike):
http://partsfinder.onlinemicrofiche....m_oem/hdmc.asp
Find your year, model, part, then put a 1 in the qty box of the item or items that you want the part number of, then click on "add items to parts list", then click on "send to cart" to get the part number.
Genuine Motor Accessories Part Numbers (chrome, etc.):
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Motor Clothes Merchandise Part Numbers (jackets, boots, etc.):
http://www.harley-davidson.com/mcm/m...bmLocale=en_US
Add /_ _ _ _ for size of an article of clothing after the part number when doing a search on Zanotti's or Chicago Harley Davidson's website's?
small........................./000S
medium..................../000M
large........................./000L
xlarge......................./002L
xxlarge...................../022L
000's are zero's not letters
Zanotti's:
https://shop.zanottimotor.com/catalog/parts
Chicago Harley Davidson:
http://www.chicagoharley.com/shop/advanced_search.php
