cam install and first problem shows up
I believe this to be an issue with your throttle body connection. There are several threads about the pins in that connection fretting and making poor contact. When that happens, limp mode it is. I would suggest you remove the connection, use some compressed air to blow out the TB side and the wiring harness. Reconnect, but use dielectric grease on the connection.
See what happens.
Also, did you check for any diagnostic codes?
so I pulled on side start her up and it start normal , putt in in first gear and it wont go, it is like I am applying the rear brake while I am holding the throttle. I heard cluncking noise in my primary. then it shut off . I notice the cluch was to tight, it is weird, then start her up , same thing happen,
could it be the clutch or primary tensioner as I heard a couple time the clunking noise in that side but I rode it back for about 25 miles and no noise or anything
[/QUOTE]
I would pull the primary cover and get a good look in there. Have you ever replaced the clutch, stator, compensator, or primary chain tensioner?
Yes it is 2010 ultra classic.
I did clear the code and start it again and only code is 2020 wich ia according to electrical manual the rear speaker short out . Didnt check the woring yet. But gonna do it .didnt have time to do last couple time. I did open the primary and drain . It was stink. Checked the tenaioner everything looks good. I changed tge stator last year sine it was leaking in the plug.
I was going to load the original map then try to ride around the block and load new map again ... i hope it will fix the problem.
Tha k you guys . Sorry i am in my phone writing
for a thought I had changed rear pad last year with some semi metallic cheap one and they didn't work well for couple ride, as I heard some whispering noise with them, then bought ebc god quality but they did the same thing. any way I end up buying new caliper and rebuild the mc last year and everything work good for 3K miles or more, now I think the rotor is warped and have to buy new one with new pad and may rebuild the mc again. I just don't understand why is this happening . I read somewhere before that hd had recall on rear brake switch causing problem , but don't think the switch will lock up the brake ...and I don't know if the first owner did take it to them to change the switch either ughhh...
