Fixing Warped Rotors
Old May 6, 2015 | 07:47 AM
SmittyFXDL's Avatar
SmittyFXDL
Default Fixing Warped Rotors
Is there a way to fix stock harley warped rotors? Ive read about using a dial indicator and using a bar or plumbers wrench to gently pull back into true, but only if its 13k's or less. What if they are more warped than that?
Auto rotors can be turned down and Im wondering if harley rotors can be pressed or made true. or is it just cheaper to buy a new set and replace.
For front touring thats 2 rotors at over 200 bucks.
Any ideas or experience?
Old May 6, 2015 | 08:17 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Man, for the money, I would not even think about messing about with my brakes rotors. They are way to important. Just get new.
Old May 6, 2015 | 08:20 AM
1plumr1's Avatar
1plumr1
IMO, if they are warped, replace. $25K machine not worth screwing with brakes that are the main stopping force. Too thin to turn.
Old May 6, 2015 | 08:54 AM
Muttleybass's Avatar
Muttleybass
I got like new take-offs at a dealer for $100. Lots of guys change them out when they get new wheels.
Old May 6, 2015 | 09:07 AM
jmn1960's Avatar
jmn1960
I have a set that I put on a flywheel turning machine at work,, turned out pretty good
Old May 6, 2015 | 09:08 AM
jmn1960's Avatar
jmn1960
i have a set that i put on a flywheel turning machine at work, turn out pretty good
Old May 6, 2015 | 09:16 AM
Uncle Larry's Avatar
Uncle Larry
I'm not sure of the minimum resurface specifications of the HD rotor but I'd be hard pressed to believe that there would be enough "meat" ( especially on a solid rotor ) to be able to refinish them and have them be thick enough to meet the minimum specification. Also, in most/many cases heat is the primary cause of warping ( especially on a solid rotor ) and machining them would ,only make it more susceptible to warping.
Old May 6, 2015 | 09:19 AM
mikelikesbikes's Avatar
mikelikesbikes
I thought I was going to have to replace mine when my front wheel came off ramp of a trailer and hit rotor. Indy checked with dial indicator and was able to pull into place and worked great. On another note I have bought them polished pretty reasonable from eBay.
Old May 6, 2015 | 09:21 AM
O-Town D's Avatar
O-Town D
OP - even if it's possible to shave the HD rotors to true them up, doing so would very likely leave you with discs so thin they would be even more susceptible to warping in the very near future as already said above. Harleys are expensive, lives are 'priceless' and personally I wouldn't cut corners on something like brakes. Hope you make the right choice.
Old May 6, 2015 | 09:59 AM
DanRC's Avatar
DanRC
Two things I would never skimp on, Tires and Brakes. I would get new rotors.
